Empted water on first rinse then tried to spin there was a loud knock and grating sound we turned the washer off straight away , then I tried on a spin cycle drum kept moving slightly but would not spin and then shut down
Sounds to me like your washer tub had a very unbalanced load in it (heavy blankets, jeans, or pillows, all piled to one side instead of evenly distributed around the inside of the tub), and it threw it off balance. When it began to wobble and knock, it may have broken the mechanics underneath the tub which make it spin. The only way to properly diagnose it is if you remove the outer casing of the washing machine and look beneath the tub for broken/out of place items.
SOURCE: noisy spin loose drum
drum bearing need need bearing kit and drum support £60 plus labour at similar price. Appliance Doctor
SOURCE: kenmore washer
It could possibly be a motor coupler that has broke. Its a small rubber disk mounted on plastic drive joints. Its located between the motor and the transmission. This coupler is made to rip or break in case of something more serious, sort of like protection for the motor or transmission. Jim
SOURCE: Kenmore 90 series noise after spin
Yes the brakes are grabbing too hard....I will sometimes lubricate them....Or replace the basket drive assy. You do know how to take the cabinet off i take it??
SOURCE: Whirlpool washer fills up; makes LOUD whine/click metal noise
sounds as if you have a bad mootor coupling, part number 285753, easy enough part to change, easier to search on the you tube site for whirlpool motor coupling repair, fo rthe video, then try to explain procedure, but definalty easy enough repair for home owner
SOURCE: Kenmore Elite top loader makes loud knocking sound when spinning
sometimes the agitator gets loose, causing the drum to sway to far all over the place.make sure its tight , remove the softener dispenser (manual nut), then tighten the metal nut that holds the agitator down
