The interior light burned out. It looks like you need a special screwdriver
Not the cooking light but the one that turns on when the door is open. A little cover opens and closes electrically to protect it from the heat lamps. There appears to be a cardboot square covering where you would change the bulb but it is held in place with a bizarre screw. What kind of driver does it take to open?
Need a bit more information here. Does it still cook when told to do so? If not, you may have a problem with the door close switch. Perhaps it is as simple as using a screwdriver to finesce the actuator back into position. The inside edge of the door has a metal latch and often times a slightly shorter pin or tab that actuates the door open switch. This not only enables the light in the microwave to turn on when the door is open it also tells the cooking circuits to disable until the door is properly closed. If the switch itself is bad you'll have to take the microwave apart to get it out. RepairClinic.com has a huge assortment of parts that are easy to search and find.
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open.
However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp. Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
When you open the door on your microwave, it sends an electrical current to the halogen lightbulb mounted inside the microwave. The signal turns on the light and illuminates the inside of the microwave. In addition, while cooking your food, the light illuminates so you can monitor the condition of your food while cooking. While the bulb generally lasts a long time, when it burns out, you must service your microwave.
1 Unplug the microwave from its electrical outlet. Never service an electrical appliance while it's plugged in.
2 Remove the screws that hold the outer shell onto the microwave chassis. Often the screws are on the bottom or back of the microwave. Use a Phillips screwdriver or Torx driver to remove the screws.
3 Lift the outer shell off the microwave chassis and locate the box that houses the halogen lightbulb. In most cases, the box is metal. It may or may not have a lid on it. If it has a lid, loosen the tabs and pull off the lid.
4 Unscrew the halogen bulb and replace it with a bulb rated at the exact same wattage.
5 Place the cover back onto the box if necessary and place the shell over the microwave chassis.
6 Secure the shell to the chassis with the original screws and the screwdriver or torx driver.
some microwave is have PCB control if pcs is shorted some parts light bult,fan or syncronus motor is on mode we need to replace the pcb but some problem is only is micro switch,if mocro swict is rusty or corroded that the time not working the turn table,but you said every time open the door the ligth is ok,if the turn table also running during open door have problem in your pcb board that we need for replacement,but check the price of parts and make it desicion if you want to repair or buy a new one if your unit is very old.
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.Advantium - Interior Light Operation While Microwaving
Check here
The problem appears, at least in part, to the door latch circuitry which cannot be serviced by the owner. If the unit is still in warranty, call GE customer care. If not, replacing the unit is your best bet. I just bought a new GE 1100 watt oven with great features for less than $100 If the door dosen't latch correctly, you could be exposed to dangerous microwave energy.
If the light comes on during cooking then the bulb is ok.. in all probability the problem is the door switch that senses when teh door is open and activates the light... Hope that helps..
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
If you think the problem is on the control panel, which we repair these nationwide for $39.95 postpaid.
We're happy to help and we appreciate your thoughtful rating of our answer.
It is possible that the magnatron is bad but hard to say on a no heat problem without checking all components. A lot of model give 5-7 yr warranty on that part.
