The scanner stopped halfway. I have unplugged it, waited a few minutes and plugged it in again. The scanning bar is not stuck halfway now but it won't scan
Wendy; If you already did a rest, by unplugging and re plug, the scanner is probably pooched. Something you can try is to uninstall scanner and reinstall, to see if it there was a problem with the software or driver.
below are links to trouble shooting, software updates, forums etc. to deal with your problem.
PRESS THE HELPFUL BUTTON
http://www.techsupportforum.com/forums/f109/hp-scanjet-4600-a-295079.html
scanner not working fully
HP Scanjet Scanners Performing Base Unit Self Test
HP Scanjet 4600 digital Flatbed Scanner
About 2,970 results (0.68 seconds)
Search Results
HP Scanjet Scanners - Scanning Stops at the Preview ...
h20564.www2.hp.com/hpsc/doc/public/display?...na...
Hewlett?PackardWhen attempting to scan from the front panel of the device, the Scan Preview window displays normally but does not show the document or picture being ...Missing: 4600
Scan stalls half way through and never finishes - HP ...
h30434.www3.hp.com > ... > Scanning / Faxing
Jan 11, 2011 - 7 posts
More times than not, the scan stops part way through (example attached) and then (after several minutes) displays the messages below:.Missing: scanjet 4600
issue Scanjet 5590 windows 7 Business 64 bits - stop during
Jan 19, 2010 - 10 posts
