Cars & Trucks Logo
Les Stockwell Posted on Feb 04, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the spark plug gap for the above car which is 4 cylinder. thanks
L Pfaff
Level 3:
Top Expert:
  • Oldsmobile Master 11,573 Answers
  • Posted on Feb 04, 2016
L Pfaff
Oldsmobile Master
Level 3:
Top Expert:
Answers
11573
Questions
0
Helped
3587335
Points
181713
1988 Oldsmobile Cutlass Ciera, original GM plug gap .045".
this is what i would gap new plugs too, AC Delco Part # R44LTS plugs probably gaped at this already.
press the helpful button
How To Change Spark Plugs on 1987 Cutlass Ciera SL 3 8L
Spark Plug Gap NGK Spark Plugs Tech Video
How to Gap Spark Plug
2answers
How do fix miss firing on the motor number 2 cylinder?
Cars are computerized these days and the sparking system does not use spark plugs any more but rather a spark module. Just like the old spark plug system though when the tip of one of the spark units wears the gap gets too wide and no longer can bridge the gap. These cannot be adjusted. My V8 Caddy engine has a spark module that had this problem so I had to replace the module which holds 4 spark units, one for each of 4 cylinders. There are 2 modules, 1 front and 1 rear. I only had to replace the front module.
2answers
What is the spark plug gap for a 2007 Nissan Altima
HERE'S THE LINK FOR THE 2.5 ENGINE,HERE/S THE 3.5 ENGINE.
3helpful
How can i change my own spark plugs on my kia optima 2006
If it's a 4 cylinder then you have to remove the "coil pack" from the top of each spark plug. Should be a 10mm socket. then using a long reach spark plug socket, remove the spark plugs. Make sure to set the "gap" of the new ones before you install. Then re install the coil packs and secure them.
If it's a 6 Cylinder then remove the plug wires from the top of the plugs, then smae as above but you will probably use a spark lug socket and a short extension with the rachet, Once again be sure to "gap" the plugs before you install. best to do the plugs ONE AT A TIME, so that you don't mix up the wires.
1helpful
2answers
Need to know the spark plug gap on a 1995 ford ranger 4 cylinder?
Hi!1
The spark plug gap is 044 (In thousandths of an inch) Caution! Gap is not adjustable on certain plug brands. The 4 cyl. 2.3 L engine uses 2 spark plugs per cylinder.
A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Replace spark plugs on a 2008 4 cylinder tribute
This is a fairly easy job. Do each cylinder one by one (removal and install), make sure to reinstall the coil on the same exact cylinder (DO NOT MIX UP). 1. Remove coil retaining scre 2. Pull upward on the coil to remove. 3. Remove spark plug (using a spark plug socket). 4. Properly gap new spark plug (if applicable). 5. Apply sprark plug anti-seize compound on plug threads. 6. Install plug. 7. Aplly coil boot grease on the coils' rubber boot tips. 8. Reinstall coil.
Mitsubishi 2004 Galant spark plug gap?
4 cylinder/6 cylinder motor--gap is .044.
But depending on replacement choice of spark plug, the gap should not be adjusted for some choices.
9helpful
Where are the spark plugs on my 2000 Oldsmobile Intrigue and how do i change them?
2000 Oldsmobile Intrigue V6-214 3.5L VIN H SFI
Spark Plug: Service and Repair
REMOVAL PROCEDURE
TOOLS REQUIRED
J 43094 Spark Plug Boot Puller
1. Turn OFF the ignition switch.
2. Remove the ignition coil assembly.
3. Use the J 43094 in order to remove the spark plug boots from the spark plugs.
NOTE: Allow the engine to cool before removing the spark plugs. Attempting to remove the spark plugs from a hot engine may cause the plug
threads to seize causing damage to cylinder head threads.
NOTE: Clean the spark plug recess area before removing the spark plug. Failure to do so could result in engine damage because of dirt or
foreign material entering the cylinder head, or by the contamination of the cylinder head threads. The contaminated threads may prevent the
proper seating of the new plug. Use a thread chaser to clean the threads of any contamination.
4. Remove the spark plugs from the engine.
INSTALLATION PROCEDURE
NOTE: Use only the spark plugs specified for use in the vehicle. Do not install spark plugs that are either hotter or colder than those specified for the
vehicle. Installing spark plugs of another type can severely damage the engine.
NOTE: Check the gap of all new and reconditioned spark plugs before installation. The pre-set gaps may have changed during handling. Use a round
feeler gage to ensure an accurate check. Installing the spark plugs with the wrong gap can cause poor engine performance and may even damage the
engine.
1. Measure the spark plug gap on the spark plugs to be installed. Compare the measurement to the gap specifications. Refer to Spark Plug Usage.
Correct as necessary.
NOTE: Be sure that the spark plug threads smoothly into the cylinder head and the spark plug is fully seated. Use a thread chaser, if necessary,
to clean threads in the cylinder head. Cross-threading or failing to fully seat the spark plug can cause overheating of the plug, exhaust blow-by, or
thread damage.
NOTE: Refer to Fastener Notice in Service Precautions.
2. Install the spark plugs to the engine.
Tighten
Tighten the spark plug to 20 N.m (15 lb ft).
3. Install the spark plug boots to the ignition coil assembly.
4. Install the ignition coil assembly.
6helpful
3answers
Spark plug gap
Notice: This engine has aluminum cylinder heads. Do not remove the spark plugs from a hot engine, allow it to cool first. Removing the spark plugs from a hot engine may cause spark plug thread damage or cylinder head damage.
Gap the spark plug, using round wire type spark plug gap gage.
Gap Adjust the spark plug gap to 1.14 mm (0.045 in).
DO NOT coat the spark plugs with anti seize compound. Over torquing could occur and damage to the cylinder head threads may result.
If your going to use Platnum plugs, DO NOT GAP them. Just check the gap and if there not the right gap, ask for new one's with the right gap.
The metal on the PLatnum plugs, are harder and my break apart in the cylinder .
Good luck and hope this helps
6helpful
How do i change spark plugs on a 2003 chevy tracker?
I don't know if your vehicle is a 4 cylinder or 6 cylinder. This will make a difference in the # of cylinders as well as the placement. If it is the 4 c ylinder when you open the hood it says at Autozone.com that the spark plugs are on the front of the motor lined up 1-4. If it is the 6 cylinder then you will have 3 at the front of the motor and 3 at the back of the motor. Regardless it is the same concept. I don't know for this particular vehicle, but it is possible you may have to remove a large plastic engine covering in order to access the spark plugs. What I recommend is to replace the spark plug wires at the same time as the plugs. For all my vehicles I use NGK plugs and NAPA auto parts has the best plug wires I have used - Belden Maxx. Prior to starting you will want to check the "GAP" on each new spark plug. Using a spark plug gap tool available at parts places for about $1. Take the new plug and the non-porcelin end (the end that has the arc) insert the arc into the gap tool at the lowest end and slide the plug around until you reach the corresponding "GAP". For this vehicle it should be .44" (I checked on Autozone's website but you may want to check to be sure. At some of the part's places they may tell you that you don't have to check the gap, but believe me you alway's should. I just did a car where they insisted that I didn't need to check the gap and each plug was not gapped properly. The Arc on the plug has to be specific for your vehicle or you will have too much spark or not enough. After gapping the new plugs you are ready to start. Somewhere on the side of the motor you should see either 4 or 6 wires/cables branching out to the cylinders. Starting with whichever you prefer (do only one at a time to avoid confusion) trace the wire/cable to the cylinder and where it goes to the cylinder a "boot" covers the spark plug. Twist the boot until it comes off . If you are going to replace the plug wires take that one off and match it up to your new set (They will be different lengths). You will need a ratchet and a spark plug socket (available at parts places) The spark plug socket has rubber on the inside to protect the porcelin of the spark plug, and to provide grip. You may or may not need a small extension. Place the spark plug socket over the end of the spark plug and apply pressure until the spark plug begins to loosen. You may have to apply quite a bit of pressure if they are in there tight. Once it is loosened take the old plug out, and place the new plug in the spark plug socket. Don't use the ratchet at this point, just begin to thread the plug in by hand once it is in there as much as you can get it, tighten it down with the ratchet making sure not to over-tighten. Do the other cylinders in the same manner.
1helpful
2answers
Need gapping info for toyota corolla AE-91 1.5l japanese domestic
The correct spark plug gap for the 1.5 litre engine is .032"
Top Oldsmobile Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you an Oldsmobile Expert? Answer questions, earn points and help others
