Question about Panasonic KX-T7731 Corded Phone
I forgot my passcode to retrieve voicemail message, can I reset without knowing what it was?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 113 Answers
Try calling your local provider.
Posted on Feb 09, 2016
6ya staff
SOURCE:
When I check voice mails asking for password . I have forgotten password how do i reset please
Depending on if you use the Instant voicemail app or call into the direct line their are different reset procedures. Additionally it will depend on the specific carrier you use. I will include some common carriers so you can use which one is applicable.
Verizon
Press *611 then press SEND (airtime is free). Alternatively, call (800) 922-0204 (toll free) from any phone to reach the automated customer service menu. Listen to the instructions then when prompted, press 4. Listen to the instructions then when prompted say "Reset voicemail password".
AT&T
Call the AT&T automated system from your mobile device. Press "1" to confirm your wireless phone number. Press "3" to select Reset Your Voicemail Password. You will receive a temporary password via free text message.
Sprint
To reset your voicemail passcode:
Sign in to My Sprint with your username and password.
Click the My preferences tab.
Under Things I can manage online, click Change voicemail passcode. The Reset Voicemail Passcode window will open.
Dec 08, 2015 | Cell Phones
How can you retrieve messages without the passcode?
Get the system administrator to cancel the passcode, then you can do this. But anyone who calls your extension and claims they are u retrieving remotely will also be able to get your messages.
Jun 11, 2014 | NEC Dterm DTP-2DT-1 Phone
Forgot unlock code voicemail kyocera jax
Go to this link...
http://www.virginmobileusa.com/resources/phones/prepaid/manual/kyocera-aw-jax.pdf
DOWNLOAD THE MANUAL FOR FUTURE REFERENCE!! LOL
Scroll down to page #39 to where it says Use Voicemail and follow the instructions!! As per the service tech I spoke to on the phone to find this link, following these instructions will automatically erase your old voicemail unlock code as well as any as yet unheard messages.
Just in case anyone still has difficulty in finding the instructions.....
Set Up your VoicemailBefore your phone can receive voicemail messages, you must set up a 4-10 digit passcode and record a personal voicemail greeting.When you have set up your voicemail, all unanswered calls to your phone are automatically transferred to voicemail, even if your phone is in use or turned off.1. Press and hold the 1 key.2. Follow the system prompts to create a password and record a greeting.
Check your Voicemail
When you receive a voicemail message, a
notification with a voicemail message icon
appears at the top of your screen.
• At the voicemail notification, select Call to call
your voicemail number and follow the system
prompts to retrieve the message.
Select Ignore to clear the notification without
checking messages. The notification icon
remains on top of the screen until you listen to
the message
• When only the voicemail message icon
appears on top of the screen, select
Voicemailand follow the system prompts
Best of luck!!
Susan
Jan 27, 2012 | Kyocera Jax Cell Phone
Employee forgot his password and need to change the voicemail for new employee. Is there a way to reset the phone. Phone model is a Superset 4025. My phone number to the phone is (563) 690-3230 or email...
Each mailbox password is held in the system programming of the voicemail system. You need the system admin password for voicemail. Dial the access code for voicemail, if from a phone with voicemail then press * to get to the main greeting. At the main greeting dial * then the system admin mailbox number which is 99 for 2 digit ext numbers or 999 for 3 digit ext numbers or 9999 for 4 digit ext numbers then you will be prompted for the system admin passcode(default 1234). Press 2 for add/edit/delete (Never press 1 for new installation or you could delete all current voicemail programming and messages). Press 2 to edit mailbox, you will be prompted for the mailbox to edit, enter the mailbox number. Press # to skip to the passcode reset, enter the new passcode or press * to reset to default(999) then press # for each of the remaining parameters until you are returned to the mailbox menu which prompts for press 1 to add mailbox, 2 to edit mailbox, and 3 to delete mailbox, then hangup.
Dec 07, 2010 | Mitel Superset 4025 Corded Phone...
I have an old MITEL 4025 in my new office. Noone seems to know how to set up the message/ voicemail option. I need step by step directions. Thank You.
You need to know the Voicemail access code... I generally set this up as 77, but other installers will set it with a different number. This will be the same number that others in your office dials to reach Voicemail when they have a message.
Your mailbox will also need to be created in the Voicemail system. When you call into it, it should recognize you and prompt you for a passcode. The Mitel Embedded Voicemail system default passcode is 1111. You will be prompted to set up the mailbox and change the passcode.
If this doesn't help, contact your site administrator or vendor.
Sep 21, 2010 | Mitel 5220 IP Phone
Change voice mail message from one person to another person
Step 1 Lift the handset for your telephone and listen for the dial tone. Dial the access code you were given by Verizon when you signed up for residential telephone service. Dialing the access code will call the voicemail system. If you do not have an access code, you will need to call Verizon Customer Servicemag-glass_10x10.gif (see link in Resources).
  • Step 2 Identify the telephone number you are setting up voicemail services for. If you are calling from that telephone number, enter the temporary passcode and then press "#." The temporary passcode is the last 4 digits of your residential telephone number. If you are calling from a different phone, press "*" when the system greeting starts to play, then enter the 10-digit telephone number when prompted. After this, you will be asked to input the temporary passcode.
  • Step 3 Choose a new passcode. The passcode must be from 4 to 8 digits in length. It should be easy for you to remember, but difficult for others to guess. Do not use easy to guess numbers, such as 1234 or 1111. Also do not re-enter the same temporary passcode, since it will be easy for anyone to guess.
  • Step 4 Record your name. Simply say your name, without a long complicated message. This recording is used by the voicemail system to identify you whenever you forward a message to another user. It is not used as the standard greeting when a caller is directed to your voicemail to leave a message.
  • Step 5 Record or change your personal greeting. This greeting is played any time someone reaches your voicemail box. Record a friendly greeting to announce that you are unavailable and will return all calls upon your return.
    Decide if you want to set up a different mailbox for each family member. Verizon residential telephone service allows you to set up multiple mailboxes so that everyone can have his own private message center. Callers who reach voicemail will be prompted to press "1" to leave a message for one person, press "2" for the next person, and so on.
  • Step 6 Hang up the telephone. When you have finished setting up the voicemail system on your Verizon residential phone line, hang up the phone to end the call and exit the voicemail system.
  • Nov 08, 2009 | Uniden Cordless Phone
    Turning off answering machine
    Hi
    you cannot retrieve messages off the voicemail system I am afraid. If this is down to malicious calls and police are involved speak to O2 as they may have a way to supply evidence direct to police?
    Regarding turning off voicemail here are the codes you need, dial 1750 to activate voicemail, 1760 to deactivate voicemail, 901 is used to call in and listen to voicemail and additional options i.e. greeting, pin etc.
    WARNING! By turning off voicemail you will ERASE any messages in your voicemail as it resets each time deactivated! So only do this is messages are no longer required!
    Hope that helps?
    Apr 26, 2009 | O2 X2i Cellular Phone
    Retrieving tracfone by using my lan line phone.
    With most providers it will usually press *, 0, or # when you hear your voicemail message come up. Let me know if that works, if not, I'll try and get intouch with someone.
    Oct 16, 2008 | Motorola Mobility TracFone C139-4 Cellular...
    Multiple log in to voicemail
    We shut the phone system off for about one minute and it reset the system without losing any of the messages.
    Feb 07, 2008 | Lucent Lands Phones
    Voicemail passcode
    Both of these problems can be cured by calling a tracfone operator. You will not loose the recorded vioce mails that way.
    Dec 12, 2007 | Motorola Mobility TracFone C139-4 Cellular...
    Panasonic KX-T7731 Corded Phone Logo
    194 people viewed this question
    Top Panasonic Lands Phones Experts
    Ekse
    martin hogg
    guyvstewart
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
