The ethernet cable is ok, the motor is ok, the stop button is ok, the resetting swith is ok, the updown motor is ok. may be the low or de upper kit? or just a configuration could solve the issue?
Gentlemen,
if your screen keeps "resetting", and it takes almost a minute with no move, and afterwards, if your screen works too slow when you see the message "press a key", problem might be the emergency stop button.
it is very easy to try. just take out 4 screws out from the bottom of emergency button box, open it up and take the cables which are closer to you out, and connect them by hand.
in this way you will be bypassing the emergency button and disabling its functionality.
then check if it works.
I attached the photo of faulty switches which should normally close the circuit, and only opens when emergency button is pressed. those ones lose their conductivity, so keep the circuit open, preventing any of your motors working.
Keep rocking..!!
BR, Bekir
So sir how we can configure ? if we receive resetting massage on panel we checked already limit switch and elevation Motor both are ok
Is the E stop cable wrapped around the handlebars? This creates tension on the switch and will block the screen.
There is a fan in the iron box. You have to change them. 2 fans required. Change both.
Problem solved. Low kit processor was died. I bought a new low kit (1000 euros) because no replacement processors are avaliable for this model.
I see this problem in turkey too much. And changing the fan. If you have problems again you can contact me. Help you.
6.11. “THE EQUIPMENT IS LOCKED (COM)” MESSAGE ON
DISPLAY
In the case of the equipment locked with error "The gear is locked” check the cause of
the reported in parentheses below:
• (COM), for errors related to serial communication;
• (EMER), for errors related to emergency button;
• (cod. error), for errors generated by Low Kit.
This error message can be caused by:
• loss of communication between the lower and upper assemblies;
• theAT UL driver has detected an error condition, causing it to generate an alarm and store
the error code in memory.
• problem on the emergency button.
To optimize the troubleshooting procedure, follow the steps below:
1. Access the item “TROUBLESHOOTING?AUTOMATIC TEST? SERIAL PORTS
TEST?Low Kit COM Test”. If the outcome of the test is negative, check the components of
the link between the upper and lower kit, in particular:
• check that the wiring of the various cables (TRM-19 and TRM-20) is not damaged, in
particular the cables of the “emergency signal” and of the “reset” by referring to
paragraph: 2.7. “Cables”, using the Test Box Excite.
• try replacing each of the circuit boards in turn (display board or digital plan board and
ALE/AT UL driver board) and check whether the communication works.
If the outcome of the test is OK move on to step 2.
2. Access the item “TROUBLESHOOTING?AUTOMATIC TEST?Inverter Test”. If the
outcome of the test is negative, check the error code stored in the “ERRORS LOG” and
perform the corresponding troubleshooting procedure, if the outcome is OK advance to step 3.
3. The machine lockout problem has to do with the handling of the emergency signal:
• check that the emergency button is not pressed;
• check that the cord, linked to the emergency button, is not to taut so that it keep the
emergency button contact open;
• check that all the cables linked to the emergency device management are properly
connected and in a good state of wear.
WARNING: if the display board detects an error condition during the tread belt motor
movement, it displays the error message and turns off the AC motor by the ALE/AT UL
driver.
SOURCE: Technogym run 700 shows RESETING.... No other function. How do i solve this problem.
when machine shows resetting , , they set it self by moving upward or down ward if not, first issue with your'e elevation motor. and limit switch as well.
