Verify that the oven is getting 240 volts from the wall plug. Sometimes the circuit breaker in the house power panel will only trip one side of the breaker which leaves 120 volts for the light and the electronics to operate on but will not operate the heating elements.
Oven temperature will be controlled by a thermostat which might be separate from the oven switch. There possibly is also a thermal fuse or breaker to protect against serious overheating in the case of thermostat failure.
One of those devices or the wiring or connections is probably faulty and continuity should be checked through the circuit with an appropriate meter.
SOURCE: Smoking Fan Assisted Oven
Is the smell a food smell or other smell. If it is food, then some food has gotten behind the blower motor. Clean behind it good. Even some small particles have gotten in there somehow. You can also feel thye sufaces of the oven and tell if there is some buildup.
SOURCE: oven problem- grill works but the fan assist wont heat up
possibility is that the wire that link the oven element and that of grill is loose or burnt
SOURCE: Hi our NEFF B1451 oven has stopped working
It is most likely that the heating element has failed but there is the outside possibility it could be a faulty oven temperature sensor.
SOURCE: The main oven, fan assisted, blew the fan element.
You to check the element with a meter to ensure if you are getting a sapply to it, if you are, then the new element is faulty, if no supply, then probably ythe thermostat is faulty, also check for broken or bad conn ections.
SOURCE: fitted new oven element still not working
Most likely the temperature sensor is bad. This is a small pencil shaped rod in the top of the oven.
Well,
to ensure the temp sensor isn't bad, you can take an ohm meter to the contacts
of it and measure the resistance. It should be around 20 ohms. If it is
much greater or infinite, then its bad. To get to the contacts
you will need to unplug the oven, pull it away from the wall and remove
the rear panel. Then disconnect the wiring
and touch the probes
from the meter to the contacts on the sensor. You can order a new
sensor locally or from repairclinic.com. Let me know what you find.
Benjamin
