Whirlpool GEW9250 Electric Dryer Logo
p
p latham Posted on Feb 03, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When dryer running there is a burning smell - Whirlpool GEW9250 Electric Dryer
Damian Appert
Level 2:
Novelist:
  • Expert 112 Answers
  • Posted on Feb 10, 2016
Damian Appert
Expert
Level 2:
Novelist:
Answers
112
Questions
0
Helped
34256
Points
274
Clean the lint trap and make sure you have good fan operation. Check your outside vent for good air flow. Could your burning smell be electrical wiring? Does it smell like plastic burning or lint burning?
These are things one needs to know in order to locate the trouble.
Why is Kenmore elite electric dryer making noise and has a burning smell?
If you have an older Kenmore dryer, the drum bearing and/or rollers may be failing. This would cause the drum to rotate unevenly (wobble) and possibly contact the heating elements on the rear panel. This would account for the banging noise and burning smell. Your dryer has to be serviced.
My Frigidaire gallery dryer stopped working it will buzz when I turn the starter knob but never starts nor does the drum turn ,then I smell a burning smell
if you can hear the motor running then probably the belt is either too loose and/or broken (you may hear a rubbing or squeeling sound).....if you cant hear the motor running then it may be burned out....a very acidy smell.
Either problem requires taking the dryer apart to fix (new belt or new motor)
Burning smell when running
fluff on the element.............cheers
Jan 20, 2014 • Dryers
2helpful
Dryer makes a burning smell while running
the burning smell is from the belt tensioner roller bearing. It is locked up making the belt to burn
Mar 11, 2010 • Dryers
When it runs, it runs too hot even on low and burning smell
needs new thermostat DO NOT USE IT IS A FIRE WAITING TO HAPPEN
1helpful
1helpful
Dryer stoped running
Your drive belt may have broken if it smelled like rubber burning. If that is the case then your motor bearing are worn out or something has been lodged between your dryer drum and the dryer housing. If the smell was the odor of burning plastic, then your motor is probably burned up.
Electric burning smell from dryer
first check your dryer vent hole and dryer wall vent to make sure there not clogged with lent,most of the time that's what it is,let me know and we can go on from there-mike
Dec 17, 2008 • Dryers
2helpful
3answers
Dryer burning smell
Have you painted or stained in your house or apartment recently? The smell gets everywhere, dryer, stove, heating unit. I recently primed with Kilz and the clothes from my dryer smelled burned. When I called for service, it was the first question the service person asked and said they made a lot of useless trips only to find nothing wrong with the appliance. That was my case. I had to rewash clothes and let the dryer run with towels for a while
Jan 22, 2008 • Dryers
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
