Question about Health & Beauty
How do I charge a moxie power scooter?? - Health & Beauty
  • Kim Hood-Baskins
    Kim Hood-Baskins Feb 02, 2016
    Where do I find the charging port on the scooter itself . Cody Grace
    New Friend:
  • 12 Answers
  • Turn the scooter's power switch to the OFF position.
  • Connect the charger's plug to the charging port on the scooter.
  • Plug the charger's power cable into a power outlet.
  • When the charger's LED red/orange light is on, the battery is charging. Optimal charging time is 6 to 8 hours, or up to 10 hours to achieve a complete charge. The scooter manual will have the exact charging
  • Times recommended for your scooter.
  • Stop charging when the LED light is completely green.
  • Disconnect charger from the scooter, then from the power outlet.
  • Run your scooter before riding it to verify the battery charge.
Posted on Feb 02, 2016
6ya staff
SOURCE:
I have a golden companion II 3 wheel scooter with new batteries, the problem isafter a complete charge the scooter starts off fine but gradually loses power as indicated by meter in 5 to 10 minutes. A
hi ,there are two parts to batteries holding power and preforming well, firstly how good are the batteries, secondly how good is the charger ?, good batteries and a bad charger will make the batteries appear bad...
Regards
Rob
www.gewizrepairs.co.uk
Feb 22, 2014 | Golden Technologies Golden CompanioN II -...
I have Moxi thru Charter Comm, How can I usa my PC to record a program on Moxi using Charter TV Listings
you could use a tv tuner pci card (prob 15-30$ at newegg)... i just run svideo from the moxi to the tv card and just use composite to watch tv (u will get a tiny amount of interference on your tv but it works cuz the moxi has video signal on both jacks all the time) then i just downloaded a program to record the feed... hope that helps
Jun 18, 2010 | Dell Computers & Internet
Just received a new moxi remote because i was having trouble with my old one. My moxi box is a silver motorola box that says broadband media center. my old remote says charter digital on the bottom and...
Do you know what model MOXI box you have? The new remotes weren't programmed to the MOXI 3012 box. If you have the Moxi MP12, BMC9012, BMC 9012F, BMC 9022 you will need to program the remote to the box.
1. Turn on the Moxi STB.
2. Press and hold the MOXI and OK buttons on the remote until the red LED at the top of the remote blinks twice.
3. After the red LED has blinked twice, release both buttons.
4. Using the numeric buttons on the remote, slowly enter 0, 0, 4. The correct entry of this code will cause the red LED to blink twice.
5. The remote is now programmed to operate the Moxi STB listed above. Go to “Programming the TV”.
Apr 01, 2010 | Televison & Video
Same problem as don5625.my moxi box will not control volume mute or power on my olevia lcd hdtv
Is this the style of Moxi remote that you have?
If so try these steps to find your TV
1. Turn on the power to your TV.
2. Press and hold down the MOXI and OK buttons.at the same time until the LED at the top blinks twice.
3. Press the numbers 9910 on the remote and the led should blink twice again.
4. Press the mute button. If the TV mutes then press OK to lock in the code. If the TV does not mute press the up arrow once then press mute and continue to press the up arrow once then press mute until the TV mutes once the TV mutes press the OK button to lock in the code.
*** Note this may take a couple minutes of trying to cycle through the code list to find which one will work with your TV *****
Good Luck...
Jan 05, 2010 | Olevia LT37HVS 37 in. LCD HDTV
Boston Acoustics TVee Soundbar loses the cable remote training.
get rid of that moxi before it starts on fire.
have charter send out a scientfic atlanta hd dvr, with an hdmi port on it as well. the functionality and reliablity of these boxes greatly exceed moxi. moxi is a power sucking, fire hazard, problem waiting to happen. the only thing it has that is good is the guide format. but you may feel that graphics on a tv guide outweigh the funcitonality of the device. the big square in the front of the moxi was supposed to be a dvd burner, the box has no hdmi, and has a modem in it that is disabled. so its got a bunch of junk on it that isnt and cant be used. if you dont clean the vents on the back of the box monthly it will surely fail.
senior catv tech/supervisor
ALL OF US INSTALLERS DESPISE PAUL ALLEN FOR INVENTING THAT PEICE OF ****.
Jan 01, 2010 | Boston Acoustics BA735 Computer Speakers
Code in Moxi DVR remote for Insignia receiver?
Type in all the codes, cause sometimes they will operate multiple electronics.
Oct 25, 2009 | Audio Players & Recorders
Can i turn e200s electric scooter on at switch when charging
No do not turn on the scooter while charging. When the scooter is on it is consuming power. So if you were to have the scooter on while charging, not only would it take longer for it to charge but it would cause problem for the battery. Because you want it to discharge while charging.
Oct 18, 2009 | Electric Razor E200s Seated ...
Moxi remote control
The "universal code" 9910 is just the first step in doing a program search. Hold down the MOXI and OK buttons simultaneously until you get the double blink. Then enter 9910 and it will blink twice again. Then begin alternately pushing MUTE and the up arrow (above the OK button). Pushing the up button effectively cycles through the codes and pushing MUTE tests the current code that it is on. Do not go too fast because when you finally push MUTE and it actually mutes (or unmutes) your TV, you must push the OK button to store that code. I just performed this procedure and my first positive code that I stored only affected the mute and volume settings on my TV and would not turn the power on or off. If this happens to you as well, repeat the above process and just skip over the first positive you get until it mutes (or unmutes) your TV again.
Oct 18, 2008 | Televison & Video
Health & Beauty Logo
146 people viewed this question
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Tilburn
Jeff Tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
