Insignia Solutions Original INSIGNIA TV remote control for NS-39D310NA15 NS-48D510NA15 NS-19E310NA15 NS-24D510NA15 NS-28D310NA15 NS-32D310NA15 NS-32D510NA15 NS-50D550NA15 NS-42D510NA15 NS-40D510NA15 NS-32D311NA15 NS-55D550NA15 NS-29D310NA15 NS-32D512NA15 NS-32D312NA15  Logo
M
Manzoor Hussain Posted on Feb 01, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I get a manual for NS-40D510NA15 - Insignia Solutions Original INSIGNIA TV remote control for NS-39D310NA15 NS-48D510NA15 NS-19E310NA15 NS-24D510NA15 NS-28D310NA15 NS-32D310NA15 NS-32D510NA15 NS-50D550NA15 NS-42D510NA15 NS-40D510NA15 NS-32D311NA15 NS-55D550NA15 NS-29D310NA15 NS-32D512NA15 NS-32D312NA15
Level 3:
  • Insignia Sol... Master 6,688 Answers
  • Posted on Feb 02, 2016
Cindy  Wells
Level 3:
Answers
6688
Questions
0
Helped
3530686
Points
21745
Insignia has the manuals for most of their products on the product page. Click on the Support/Downloads tab. For the NS-40D510NA15, see http://www.insigniaproducts.com/products/televisions/NS-40D510NA15.html . The direct link to the User's Guide (as a PDF) is http://www.insigniaproducts.com/cms/documents/manuals/NS-40D510NA15_14-1088_WEB_V3_ENG_Final_lr.pdf . There is additional documentation available and there is an HTML version of the user's guide as well.
I hope this helps.
Insignia NS-40d510na15 has the sound but no picture problem. looking to replace the blacklight inveter but not sure how to remove the silver 1in wide tape connect to the inverter
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board
tip
Insignia NS-PDP50 Manual Download
Download Insignia NS-PDP50 Plasma HDTV Manual
Have you misplaced your Insignia NS-PDP50 Plasma HDTV Manual ?
Would you like a digital, searchable, pdf version of the Insignia NS-PDP50 Plasma HDTV Guide?
Follow this link (& click FREE) to download a pdf version of the Insignia NS-PDP50 Plasma HDTV documentation.
I hope that helps.
__________________________________
on May 08, 2010 • Televison & Video
On the Insignia TV remote, how do I get back to being able to choose channels with Direct TV remote?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code
Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
Led power light comes on but screen will not come on.
"Blinks a few times" implies the TV is flashing a fault code at you. If you can find a service manual for your model, count the number of blinks and look it up in the diagnostics section.
However, the most likely problem is a burned-out electrolytic capacitor in the power supply. These are usually easy to identify visually; the top of the can-shaped capacitor should be flat, but may be bulged out and may have brown or black material leaking from the vent scores. The photo below shows a bad capacitor to the right of a good one; both have black plastic sleeves.
If this is the case, replacement capacitors are relatively cheap. However, you should look for the following criteria in choosing a new part:
>Capacitance (uF): same as the original, or 10% higher if the original value is not available
>Voltage: same or higher
>Temperature: Maximum temperature should be same or higher
>Physical size: should fit in the space occupied by the original; if buying a taller unit, make sure it will fit when the back cover is reinstalled, and make sure the capacitor will not touch heat generating parts such as heat sinks, resistors or large transistors.
>Ripple current: get the highest available without compromising too much on endurance. Ripple current may be specified in mA or A; 1 A = 1000 mA. Sometimes you can get a better rating by going to a higher voltage part, but physical size may be a limitation.
>Endurance: Try to get 8000 hours or better.
I usually use Panasonic FR1 series capacitors, although United Chemi-Con EKZN capacitors are also worth a look. 25351068-tkog3zu3xmxabptjkcidpctj-1-0.jpeg
Which remote do I use to put tv on full screen
Some programs do not completely fill the screen at any setting. The remote that came with the TV has the most functionality.
2answers
How do I set up a PS2 on an Insignia NS-40D510NA15 flat screen tv?
That seems like all you should have to do. Are you selecting the correct Input Source on your TV???
Top Insignia Solutions Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you an Insignia Solutions Televison and Video Expert? Answer questions, earn points and help others
