Question about Casio Wave Ceptor WV57HA-1AV Wrist Watch
Shorten watch band. - Casio Wave Ceptor WV57HA-1AV Wrist Watch
6ya staff
SOURCE:
Anonymous
  • 4 Answers
SOURCE: how to adjust metal wrist band on casio watch?
  1. Pop out one spring pin to disconnect the band from the watch or from itself at the clasp. If you don't have a special tool for this, a needle or a pin will probably work. A straightened paper clip may be too thick, but they are cheap so you could try it. Now the watch and band can sit flat on the work table.
  2. Examine the links. If some of them have little arrows on them (usually the ones closest to both sides of the clasp), they are removable.
  3. These removable links are held together by a "U" shaped (actually a squared off "U" - sort of like this |_| ) pin that is inserted into the link. There may should be some kind of window-like opening in the link into which you can insert a narrow screwdriver or similar tool or even a small nail (around 6-penny size) and push out the |_| shaped pin. A straightened paper clip is probably not sturdy enough, but you could try it. Push in the direction of the arrow (from tail to point). The links that were joined by the |_| pin can now be separated.
  4. Remove a second such pin from another adjacent link. Now a single link is free and can be discarded (or kept). Reconnect the remaining adjustable links with one of the |_| pins and re-attach the spring pin from step 1 so the band is reunited with itself or with the watch.
  5. Try it on. If it is still too long, repeat the process. Good luck.
Posted on Mar 24, 2009
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: Can not figure out how to remove links from Casio watch band
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Apr 01, 2009
Anonymous
SOURCE: I need to shorten the metal link watch band of my
I just looked at the watch band link more closely and figured out how to remove the links. Pretty engenious link attachment arrangement!
I thought there would be something in the watch manual about band adjustment, but there wasn't. I guess it is not something a "normal" person would be able to do.
Thanks,
Steve Zansler
Posted on Jan 02, 2010
gemineye61
Janelle Schoonover
  • 842 Answers
SOURCE: How to shorten up a Casio watch metallic band
Thank you for contacting FixYa.
This link shows most watch band sizings:
http://www.webwatches.co.uk/how_to.htm
Best regards. Jewel
Posted on Sep 14, 2010
Jimmy Accardi
  • 101 Answers
SOURCE: I want to shorten my watch band on my new Casio
In order to remove the links of your Mtg930 watch you will need a couple of tools . It is recommended to have a watch pin pusher and a spring bar remover tool in order to do so. If you do not you can use a small precision flat head screw driver , the size that is usually used to fix glasses or smaller.
First you need to lay a cloth down at a table . Lay the watch on top of cloth to prevent scratching . flip the watch upside down and have a good at the back of the watch bracelet.
If you look carefully you are going to see notches on the back of each link with an arrow pointing in. This is where the spring bars are accessible and can be pushed in to remove the link.
You need to place your spring bar remover, pin pusher or precision screw drive in the notch against the edge.
Mean while push the opposite side of the watch link up so you can see the most of the spring bar inside the notch.
The spring bar is going to look like a pink with a notch on the the top then gets smaller. As shown below on the left side of the picture. If you are looking at the notch on the spring bar, that is where you need to get our tool ontop of . So you can push down the spring bar.
Once you push down on that notch on the spring bar the link will be able to slip out . Without a spring bar remover it will be more difficult and you will need to be patient as you try to work your flat head screw driver into the notch and be able to push down . Once the pin is push down you need to pull the link from the rest of the bracelet.
Do not be surprised to take anywhere from 5 to 30 minutes if you have no experience and not have a spring bar remover.
Once you removed all the links you desire , You will need to put the spring bars back into the links and close the watch bracelet up.
The easiest way is to slip spring bar into middle of link. Bring the other end of the bracelet over so it the bottom covers the other link with the spring bar head out. Push the spring bar down with your tool as you slide the links back together.
Posted on Oct 18, 2010
How do I shorten ******** my Tag Heuer Formula 1 watch?
Take a look at the watch from the side where the band attaches to the buckle. You should see four holes with one of them having a visible pin in it where the band is connected to the buckle. Moving the band to the right will shorten it moving it to the left will make it bigger. To move it simply get something that you can push the pin in with like a paper clip. Push the pin in and the band should come out move it to the left and push the in again and simply move the band into proper position. Once you do that the pin will snap back into place. If that does not adjust it enough go to your local watch store and they can remove links from the bracelet for you. Shouldn't cost you more than $10.
Dec 14, 2013 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Shorten wrist band on a RADO CERAMICA JUBILE mens watch
mcdevito75 here, Rado a great watch and with a $50.00 band, at least. BEST BET, look for a small watch repair shop in your area for this band adjustment. Links are held in by special pins and a link remover tool is need to remove these links.
Feb 11, 2011 | Watches
Stainless band too large. Need to shorten
take it to a jewler or watch mender cost £3 pounds to shorten i advese not to do it your self they have the tools to do it
Oct 01, 2009 | Baume Et Mercier Capeland MOA08491 Wrist...
Purchased fossil ladies watch am4183 at Macy's, stainless steel band is too big, is this band adjustable, if so how.
Check the sides of watch band and you will see the pin ends. They are holding all links together. If there are arrows inside the watch band, they are pointing the way the pins must come out.
To shorten the band you have to:
Extract the pins.
Take link(s) off.
Join the rest of band together and drive pins back.
Jan 01, 2009 | Fossil JR8096 Wrist Watch
Shorten band
Hi Go to www.skagen.com top r/h search box - input your model number click on go,
On the new page at bottom/left, click on customer service.
On new page left side click on instructions.
On new page you will find instuctions on how to shorten/lengthen bracelet.
Oct 24, 2008 | Skagen 107SSSBD Wrist Watch
Skagen mesh band shorten
just solved the mystery...U probably have too ..by now....but just in case..
here is a fun link to the solution by an actual user....was actually inspired by him...coz like I said I had mispaced the manual...
http://www.amazon.com/review/product/B0000C9ZBX/ref=dp_top_cm_cr_acr_txt?_encoding=UTF8&showViewpoints=1
I just used my nail file and lifted the locking mechanism and moved it forward...Now I can sleep better tonite....!
Mrs Martin
Oct 24, 2008 | Skagen 355LGSC Wrist Watch
Need to shorten a band
you better pick one and size it according to your size, if not enough, pick one again to other side of the band in order to balance ,,until reach the size you want....
Jun 24, 2008 | gossip Watches
Item number L12445 band adjustment
How do I shorten the links on a woman's eco drive citizens watch band?
Apr 22, 2008 | Watches
Casio Wave Ceptor WV57HA-1AV Wrist Watch Logo
165 people viewed this question
Top Casio Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Jerry Greenberg
Jerry Greenberg
Are you a Casio Watch Expert? Answer questions, earn points and help others
