Last year, I had an issue with my garage door opening and closing and I had to have someone come and repair it. The problem turned out to be that one of the door parts was loose and the sensor kept picking up on that. However, Gabriel says that it might be the force setting and so if adjusting that doesn't work, then you know that one of the parts is loose and needs tightening or replacement. Waukegan IL Garage Door Repair Premier Door Corp
What about force setting. It should be set about a little less than half. If it hits the ground and bounces back up even after you positively check the travel limits than its the motherboard/logicboard.
