Humidifiers Logo
The automatic damper sticks open unless I close it with a rod I was wondering if the spring was bad?
As soon as I force it closed the humidifier starts to work but the next time it has to work again it sticks open.
2 Related Answers
A
Anonymous
  • Posted on Dec 31, 2007
SOURCE: HM5081TG Reset Light won't turn off
I'm sure you've read the instructions, but in case you've misplaced or forgot them, to reset the "reset" you have to unplug the humidifier for 5 minutes.  The steps are:
1. Turn knob to "reset." 2. Unplug the unit. 3. Refill and replace tank on unit. 4. Wait 5 minutes. 5. Plug unit in and turn knob to "high."
If that doesn't turn the reset light out, re-do all 5 steps.
Hope this helps.
Anonymous
  • 3 Answers
  • Posted on Jan 07, 2011
SOURCE: Should my damper be closed
No. Open in the winter and closed in the summer
2helpful
Water leaking / running from top of humidifier
humidifiers have a drain and if there is water going in it will be coming out the drain. check drain to see if it is clear, check hoses going into top of humidifier for cracks, check filter in humidifier.
Water runs continuosly on my Honeywell Envirocaire Elite system, no matter what setting I have the automatic humidity control set at, should I try replacing the Kip valve #3703?
Try to disconnect the main power to the unit and if the water valve is still open and water is running, you have a bad valve (the valve stuck open). Tap on the valve body it may help on sticking it, if not replace it.
As soon as the water valve opens to let water run through the system it closes.
Hello, sounds like either a low voltage wiring issue or the solenoid is bad. I would check the wiring and make sure it is all secure and tight, if the wiring checks out good replace the solenoid valve.
1helpful
Loud vibrating noise when the furnace blower starts up.
Try closing damper slightly between humidifier and furnace????
2answers
Bad Problem with solenoid valve.
If the valve noise is excessive, or more than it was originally, then yes, replace the valve.
If the noise is no worse than it was originally, then you may be overly sensitive to the noise its making.
Also, check that the valve has not shifted slightly in such a way that it's opening and closing rattles it against something that it didn't used to rattle against. A sheet metal panel will amplify the valve opening and closing.
Let me know what you find.
He220a water not going thru solenoid
trace thre copper tube backwards to where it connects to main water line if there is a valve there open and close it if your not sure whats open or closed try it both ways there is also a little restriction device either on inlet or outlet of solenoid that may be clogged
Water flow to my model 600 seems to be too quick. It splashes all over inside my furnace duct and over fills the drain causing water to run all over the floor. Could this be a bad selonoid?
It is not likely to be caused by the selonoid valve. The selonoid is designed to be either open or closed, so if the unit is calling for humidity, it should be 100% open allowing as much water as possible to flow through. In cases of a bad selonoid, it will usually stick open or stick closed, but I have never heard of one allowing too much water through. Check to make sure your drain is clear and that the incoming line to the humidifier is positioned properly on the inside of the unit. If this doesn't solve the problem, it could be that the water line to the humidifier is too large, allowing more flow than the unit is designed for.
2answers
Emerson furnace is not igniting
limit switch may be stuck open.open top door on furnace switch is round with little black hose on it. disconnect hose from furnace side and **** on it to see if it will close.reconnect hose and try furnace
Water leak
Sounds like the air flow is too great and it is blowing the water in the bottom of the tray around before it gets a chance to drain. Try placing your summer, winter damper at half closed to slow the airflow down a little.
Top Honeywell Humidifiers Experts
Paul Carew
NOEL
NOEL
Are you a Honeywell Humidifier Expert? Answer questions, earn points and help others
