Can't erase last message and can't get any messages recorded after that.
SOURCE: Recording messages
You are asking about changing you voice mail and phone system settings. Your phone can work on several different Panasonic phone systems and you could have different voice mail systems as well. The phone KX-T7633 has only a user guide that covers the basic features of the phone itself. You need a programming and installation manual for your phone system AND your voice mail. They are not the same part and have different manuals. So, your first step is to find out the model number of your phone system and voice mail system.
SOURCE: Record a voice message on the oanasonic KX-T7630
the panasonic KX-t7630 doesnt have a answering machine and runs through voice mail.. if you have voice mail set up simple dial your number for voice mail (eg. 500) press 311, then record greeting at the end of tone. hope that helps
SOURCE: Transfer calls to voice mail
It depends on what system the 7731 is attached to. If it's a TA system, that you dial either 107 or 115 to get to the Panasonic brand voice mail system, you take a spare button from the left side keys and press PROGRAM the spare button and dial 94+107 or 115 then STORE.
Pick up the handset and drop it back down to end programming. Then label the button VTR. When a call comes in, you press VTR and dial the extension or press the DSS (extension) button. You don't press HOLD or TRANSFER, just the VTR button.
It's all on page 158 of the OM http://www.public.carl.airpost.net/Pana/TA-824/200_TA_OM_07-04%5B1%5D.pdf
If you are not using a TA series system, the instructions may be different.
Carl
SOURCE: can not get rid of New voicemail message
Press and hold the off button until the handset beeps
SOURCE: New Voice Mail message
You received a message on the voicemail system provided by your telephone company. To hear the message, dial the voicemail number provided by your service provider (in many cases, this will be your own phone number), and follow the voice instructions for listening to your messages. You need to store the voicemail access # by pressing [MENU], [#] [3],[3],[1] on the handset. To access the voicemail, press [TALK], then softkey [VM]. Depending on your service provider, you may need to clear your voice mailbox to remove the notification.
Hello you can erase the recorded messages one by one or all massages in folder at time
Note once a recording has been erased, you cannot retrieve it.
Erasing messages one by one
1 Press ERASE while playing back the massage you want to erase or press ERASE for more than 1 second during stop mode.
A beep will sound and the message number and "ERASE" will flash while the first and last 5 seconds of message is played back 10 times
2 Press ERASE while the message is being played back.
The message is erase and the remaining messages will be renumbered. (For example, if you erase Message 3. When erasing is completed, the unit will stop at beginning of the following message.)
Erasing all messages in a folder
1 Press FOLDER to select the folder you want to erase.
2 While pressing STOP, press ERASE for more than 1 second.
"ALL ERASE" will flash for 10 seconds
While the display is flashing, press ERASE.
