Model is PTH153G5OAX. I just installed 2 of these and decided to add the wall thermostats, not really relevant as they were both showing the same shut-down of the H.P before I did this. Why shut off the compressor before the room gets even close to set-point? The unit then switches to back-up heat. I am an HVAC tech. w/51 years in the industry. I buy a heat pump to save energy, my home central unit works as expected; run the HP as long as possible considering outdoor temp's. Why are these package units set up this way? Can I change this?
Im guessing its there way of defrosting the coils , as with this type (small) its tough to defrost the coils in an efficient way , hp runs normal to within one or two degrees of setpoint , hp shuts off or reverses in low speed , back up heat comes on to complete the room heat and to generate the heat needed to defrost the coils , entire unit shuts off when set point is reached , reversing valves set for heat and wait till next cycle
now mine does something slightly different : it runs for fifteen minutes and if set point is not reached it switches to back up and reverses the coils ,leaves compressor on (low speed) , this heats the coils up and defrosts the outdoor unit , and if it runs long enough twenty minutes total time , it goes back to normal and aux heat shuts off . this drives me insane thinking how much im spending on heating the outside !! but im sure its needed to prevent ice build up on outdoor coils ,and I sure don't want that cracking with ice formations
