SOURCE: colour problems
Your CCFL lamp has reached "end-of-life". They go pink when they are old. You can get replacement lamps here: http://jkllamps.com/index.cfm?action=fam&tid=2&fID=45 They can also help you with the job, better consult them before ordering anything. Good luck
SOURCE: lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
SOURCE: Bad picture/colours on Samsung LCD TV
loretta change your power pack
entwined try another cable
SOURCE: red tinge on tv screen when laptop plugged through HDMI
Neo2123 is correct.
The HDMI output is setup as a second disply, not Primary disply.
You will need to get into the video Driver settings and configure this for a single monitor.
1. Right click on the desktop
2. select "graphics properties"
3. set up the "Digital Display"
All the steps or naming may be different on you computer, but some of this is fiarly standard.
SOURCE: No sound on my Samsung tv when I use a HDMI cable
hello..try to change the sound settings to HDMI..you say when you use other cables everything is fine so the TV reconizes the HDMi as a video only so your sound settings should be changed to HDMI
