.I HAVE NOT SWAP THE POWER BOARD...I DID NOTICE A BLACK SUBSTANCE BENEATH THE POWER BOARD...ASSUME IT WAS DUST
SOURCE: Vizio L32 hdtv10a..
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
SOURCE: Vizio L37hdtv10a fails to fully turn on
You will have to isolate the main board and Inverters.
Unplug the inverters and turn on the set.
If it "turns on" then try re-connecting each inverter seperately to see if only one is causing the problem.
SOURCE: my vizio gv42l fhdtv 10a picture flickers like a
you need to check first the power supply board whether the output supply 12-24vdc for the inverter board is stable and not flactuating..you can measure the output voltage with a multitester..you get a voltage output of 12-24 with the inverter board is connected or loaded to the system.be carefull of the high voltage at the inverter board..once the output is stable replace the inverter board or you can measure the output of the inverter be very carefull..the output range upto 500vac.be carefull..if the high voltage is stable replace the lamps...tnx and good luck..
Testimonial: "Thanks again. :)"
SOURCE: Vizio SV470XVT1A has no backlight
The 24vdc is turn on by the signal from the main logic board, it is not always on, the standby 5vdc is always on. So yes it can be the power supply board is bad, but just to besure we need to find out if it is getting the turn on signal from the main board first.
You can have 24vdc at the inverter board and it will not light up the CCFL until it gets the signal from the main logic board to turn the lamps on (this is the STANDBY condition, the TV is on but the screen in not lit up util it see the video signal).
Send me good clean and clear pictures of the power supply board, [email protected], connectors of the Power supply, bottom side of the board, then I may be able to tell you which pin is a control input pin. Most people will just throwing parts in and hope that they one of the parts will fix the problem. Used Power supply module for this TV is over $100. http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=delta+DPS-379AP&um=1&ie=UTF-8&ei=USsxTKn3J6TonQfFlJGEBA&sa=X&oi=product_result_group&ct=title&resnum=4&ved=0CCsQrQQwAw
http://www.shopjimmy.com/catalogsearch/result/?q=Vizio+SV470XVT+
Testimonial: "Bud helped me fix my TV! It was only 1 1/2 years old. I was looking at a repair bill close to $300 - $500 and I fixed it with a $60 board! Thanks!!!"
