The spring came out and we bought a new one but can't for the life of us figure out how to install it. Help.
Best way is DO NOT use the spring.Use a common elastic at the bottom of the folding flap run around the flap to a short small screww you would drill into the plastic under the door.This lasts longer than the spring and when it gets tired,just replace with another elastic,lasts for years and works better.
SOURCE: Does anyone know how to replace the hinge DA61-04866A on a Samsung french door vertical panel
unclip the plastic cover off your door hinge and unscrew the screws on your door make sure you leave the top screw in just a bit so you can take it out with your fingers before you drop the door ok same for both sides
Removal of Cabinet
(Do not use decorative panel to move the machine)
1. Isolate power supply.
2. Remove service and decorative panels (refer Section 6.1).
3. Ease machine forward for all round access. Be careful not to damage floor coverings.
4. Remove two screws from bottom sides of cabinet rear.
5. Remove the top screws on left and right hand sides of the cabinet rear.
6. Remove two screws securing the rear bottom panel.
7. Remove five screws securing the stainless steel frame to cabinet wrapper at front of machine. These are located behind the sound gasket and service panel.
8. Withdraw the cabinet assembly away from the machine.
Refitting: Refit in reverse manner. Fitting the top centre screw in the cabinet wrapper first, makes fitting the cabinet easier.
6.9 Removal of Door Tension Springs
Location: The door tension springs are located either side of the machine and are
fitted to the chassis base and door quadrants by means of the end hooks of
these springs.
After isolating the machine from the power supply:
1. Ease machine forward for all round access.
2. Remove service panel (Refer Section 6.1).
3. Remove two screws in the cabinet wrapper exposed by the Service Panel.
4. Remove the springs from the quadrants and the chassis base using pliers.
6.10 Removal of Hinge Assemblies
(Do not use decorative panel to move machine)
Location: The hinge assemblies are located either side of the door and retained by means of two rivets on each side to the inner door panel.
1. Remove service & decorative panels (refer Section 6.1).
2. Remove outer door panel (refer Section 6.2).
3. Remove cabinet (refer Section 6.7).
4. Remove door tension springs (refer Section 6.8).
5. Remove quadrant grommets.
6. Open door fully and drill out the two rivets from the hinge assembly on inner door panel.
7. Hinge assembly can now be removed from inner door and cabinet.
Note: Hinges should be replaced one at a time. Repeat procedure six and seven for other hinge. Hinge guide quadrants can now be removed by depressing sides and pulling free of slot if need be.
Refitting: Refit in reverse manner using 3/16 monal rivets to secure the hinges to the inner door.
