In your office network, for sure, you have a DHCP server who gave the IP addresses to all devices for that network and this seems to be the reason for why you could see your NAS. On home, you also need a DHCP server. You don't say anything about you home network. The best idea is to just make a temporary network with 2 devices: your computer and your NAS by connecting the NAS directly to your computer's network adapter, set the IPV4 IP for that adapter to the same class addresses as your NAS was set by default (usually NAS had "192.168.x.y" where "x" could be 0, 1 or 2 "y" could be any value between 1 and 254, but mostly, 1) and try to access it via http to manage him (need a user name and a password). For NAS default address and username and password, consult NAS user manual. Access it with from your preferred browser using: \\192.168.x.y
Once you gain the control, cut off his DHCP service and tell him to accept the IP address from the network defined DHCP. (btw: one normal DHCP server is allowed on one network! Cascaded DHCP also is allowed, but it's a little bit complicated) Good luck!
i am having a similar issue with my Panasonic G20 and Dlink DNS-323 NAS drive. I installed Twonky 6 and it worked for a short while and now does not even list the server in the list of the TV. Anyone else know what NAS drives are compatible with this TV?
I am having similar problems with my HomeBase. I have 3 x 1Tb Seagate external USB2.0 NTFS drives (FreeAgent) connected. The aim is to have my digital TV, LG set-top box, Apple TV, PC and Laptop all access the files and capacity offered by the NAS option.
They work fine in 'single user network USB' mode, but are very flaky / non-existant in 'NAS, multi-user' mode. There are times when the HomeBase is restarted and recognises one or more of the drives in NAS mode, but mostly they are not recognised. On the back of the unit, you can see the LED next to the USB port leading to the drives initially stay lit, but then flashes for 10-15 seconds and then goes out.
As I want the hard disks available to multiple devices I need to use the NAS setting.
Did you try to set the drives into 'Network USB mode' rather than NAS mode. Does that help?
Did anyone have a solution to the problem? Unfortunately Belkin technical support have not been very useful yet...
I do exactly as above, but cant access the NAS. I can reach it from an XP machine and from another win 7 machine, but not this win 7 machine. Whats the problem?
Configure your network's DHCP-server to *ALWAYS* give the *SAME* IP-address to the NAS -- use the (unique) MAC-address of the NAS's network-adapter to assign a "static" or "fixed" IP-address to the NAS.
Probably the NAS got the same IP address of the router/switch. Something like 192.168.1.1. Try changing your router default IP address to 192.168.1.3. Look for the NAS now.
