2006 Ford Focus 2.0 Logo
k
kpawley1773 Posted on Jan 27, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Please someone help me. I've tried to connect to Bluetooth. I get so far along and then phone Bluetooth doesn't find the cars. Is there a fuse that might if gone? I did not get a manual with my car.
Kardoc
Level 3:
Top Expert:
  • Ford Master 7,503 Answers
  • Posted on May 22, 2020
Kardoc
Ford Master
Level 3:
Top Expert:
Answers
7503
Questions
0
Helped
2759548
Points
58323
Https://www.youtube.com/watch?v=3SV6w9pkJQg
Watch this video for pairing your phone to the car
Maurice Kempeneers
Level 1:
  • Contributor 2 Answers
Maurice Kempeneers
Contributor
Level 1:
Answers
Questions
0
Helped
1640
Points
7
Look at https://www.twenty4sales.com/product/bluetooth-fm-transmitter/ you can easily turn your old radio into a bluetooth device
Claude Kayser
Level 3:
Top Expert:
  • Ford Master 9,098 Answers
  • Posted on Jan 27, 2016
Claude Kayser
Ford Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5066861
Points
28436
About 4,890,000 results (0.54 seconds) Search Results
    How to Fix Bluetooth Pairing Problems - Techlicious
    www.techlicious.com/how-to/how-to-fix-bluetooth-pairing-problems/
    Dec 29, 2015 - Determine which pairing process your device employs. ... Let's say you want to pair your phone with your car's infotainment system so you ..... If your tabletdoesn't come with built-in Bluetooth (and it looks like most, if not all, ...
    www.techlicious.com/how-to/how-to-fix-bluetooth-pairing...-/CP2/
    Dec 29, 2015 - Let's say you want to pair your phone with your car's infotainment system so you can .... i factory reset my tablet and now it wont find my bluetoothspeaker to pair! .... It doesn't look like you can revert to the previous firmware ...
    Bluetooth FAQ for Windows Phone ' Windows Phone How ...
    www.windowsphone.com/en-us/how-to/.../bluetooth-faq
    Windows PhoneRead the Bluetooth FAQ for Windows Phone and get answers to common ... You can pair your phone with a variety of devices that use Bluetooth, such as the hands-free system in your car, headsets, speakers, ... Where can I find it? .... ?My phone doesn't reconnect to the Bluetooth hands-free system when I get in my car.
    iPhone 6 not connecting to car Bluetooth ' Apple Support Commu
Bluetooth not working
Good afternoon Art.
A soft copy of the owners' manual for the 2011 Malibu can be found here:
https://www.chevrolet.com/content/dam/Chevrolet/northamerica/usa/nscwebsite/en/Home/Ownership/Manuals_and_Videos/02_pdf/2011_chevrolet_malibu_owners.pdf
if you scroll through to manual page 7-25 (PDF Page 180), you'll find the info on pairing bluetooth stretching on for quite a ways. It looks like it can practically elope with your phone along with passing along phone calls.
I'm hoping that can help you run through pairing or diagnoses.
(The other thing to potentially look for might be a blown fuse. Forums like this one
Bluetooth phone icon stuck on and radio won work place bluetooth with the Audio System fuse, and say pulling the fuse and then replacing it will reset the Bluetooth as well. The manual noted above, starting on manual page 10-35, goes over the location of all the fuse panels, and pairs fuses to function.
Hope this helps you get to the bottom of it.
Good Luck!
D
1helpful
Engine won't start, starter makes rattling sound
sounds like the battery disharged. If the key was on along with the lights than 20 minutes would be enough to drain the battery. Try a jump start. it should get you going. I would have the battery tested after driving for at least an hour at highway speeds just to make sure it is good.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
THE TURN LIGHT RIGHT BACK NOT WORK
If one tail light works, it's not the fuse box. It's either a ground wire off on that side , or a wire chafed along the curcuit. Your fuse for parking lights is for all four. If you have three, it's definately not the fuse box. You did not say what type of vehicle you have or I could have told you the best places to look for a ground wire. And I'd like to know if signal, brake, and reverse lights on that same side work at all. Let me know what your car is and we'll go from there. Please rate this solution thanks
How do you remove the round plastic ring that covers the fuel filter assembly on a 2003 Hyundai Elantra GL? It looks like it screws off but it's stiff and doesn't want to move. Help?
those cars have the filter as part of the fuel pump inside the tank,What you are describing is the lock ring for the fuel pump module that needs removed first then the module can be removed
1helpful
2answers
I have a 2000 chevy silverado 1500. 3 nights ago, my truck started up just fine with no problems and has never had a problem starting up. The next morning, I tried to start it and the dash lights and radio...
do you have remote start on that truck? if you do, it has a hood safety switch that will keep it from starting if hood is open. That hood switch is quite easily identifyable. Look for it on the drivers side, either close to the firewall or right at the front of the fuse box.itsa worth taking a look
I have a 1999 Subaru Impreza Outback Sport, 2.2 liter w/AT. My issue is that it doesn't want to accelerate until I hit 3500 rpm, then it will take off like a rocket until it shifts and the rpm's...
Transmission range sensor or better known as the neutral safety switch. Also check the transmission fuse, EAXT fuse. They are both the same fuse.
2helpful
2answers
Why doesnt my transmission make shifts speedomiter
First check the 10 amp fuse #1.
If fuse is good, speed sensor has failed or is disconnected. Check connection. If connection is good, replace sensor.
Sensor is mounted on transaxle output. It should have a 3-wire connector on it with one yellow, one orange, and one black wire, as shown in diagram below.
Please let me know if you have questions.
What do you turn on in car to get bluetooth to
on the radio keep pressing the mode button until blue tooth comes up
go from there
all the details are in the user manual
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
