SOURCE: ryobi gas trimmer
I don't mean to over simplify this, but are you using fresh gas? Gas string trimmers are extremely ticky when it comes to gas. They like it SUPER fresh. And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with string trimmers, and it fixes the problem 75% of the time.
Hope this helps!!
chad
SOURCE: ryobi leaf blower #8544,25.4 cc
I have a McCulloch, that the hose rotted off the fuel strainer in the tank, I replace the hoses, it ran for awhile then stopped, removed the carb. an have cleaned, { 7 Times} it runs for awhile then stops, Usually I dump lighter fluid in the carb. if it starts Ign is OK if not its a fuel problem. You could check on the filter, I still have a problem with mine, its a pain when your on the roof an it stops. so check the fuel filter is the only thing I could suggest to you GOOD LUCK
SOURCE: toro recycler will run until primed gas is consumed.
The problem is that the gas that sat in the carb all winter glazed it over and gummed it up. Begin by going to any auto parts store, like an aiutozone, and getting a bottle of carb. cleaner. Seafoam is one I use. Add it to your gas, one ounce per gallon of gas. Also, pick up a can of engine starting spray.
Remove the air filter and spray the engine starting spray into the air intake. Pull start the engine and give it additional squirts of engine starting spray until it runs smoothly.
SOURCE: Ryobi CS30 will start but when I pull on the
Check the fuel lines first for cracks. If they are cracked or brittle, replace them. Also, your carburetor may need cleaned. Use a Den Tek Brush, (used for cleaning between teeth), to clean the small portals. Make sure the small screen in carb. is free of debris. The smallest of particles can cause your problem. Reassemble and try starting. If it still acts up after all this then you will have to purchase a carb. kit and replace all appropriate parts. If you need tips on these remedies, feel free to ask.
Jim
SOURCE: My new Ryobi boggs down/ stalls as soon as I pull on the trigger.
i had the same problem and it was drawing air at the base of the head so i thightened up the bolts and run sweet colin
