HP Deskjet F4180 All-in-One InkJet Printer Logo
Sarjo Darboe Posted on Jan 27, 2016
What cause blinking lights.
This printer's hp deskjet f4180 cartridge-black light keeps blinking.I chaged the cartridge but the problem is there.I would be grateful for your kind assistance.Thanks.
5 Related Answers
Evilsmith
Eric Smith
  • 26 Answers
  • Posted on May 07, 2008
SOURCE: hp deskjet 842c blinking ink cartridge light
You have to take off the clear strip of plastic over the copper area, or the printer will not detect it. There should be a green pull-tab on the cartridge.
Anonymous
  • 45 Answers
  • Posted on Jan 20, 2009
SOURCE: HP F4180, lights blinking - on/off, color, black, resume
Hi Guys,
Please check the following link and its the same for Deskjet F4180
HP Deskjet F4210 and F4213 All-in-One Printers - Blinking Lights- c01632938
HP Deskjet F4200 All-in-One Series - Blinking Lights - c01365789
Thank You
Anonymous
  • 5 Answers
  • Posted on May 29, 2009
SOURCE: Hp deskjet D2560,incompatible cartridge
pls check your cartridge carrrier.
Anonymous
  • Posted on Aug 06, 2009
SOURCE: HP Deskjet F4180 colour lights flashing and printer offline
Hi I have exactly the same problem, and can't scan or make copies. I went to HP Online, and tried their advice, which didn't work. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00867129&lc=en&dlc=en&cc=us&product=3177566&rule=25623〈=enHP's solution made me realise it might be a scanner problem. I made a wild guess and kept the cover above the glass panel open. Turn off your printer, lift the cover up and turn on again. The lights should stop blinking and you should be able to scan/copy/print. I guess the cover prohibits the device to scan properly causing the blinking lights. Hope this helps!
Anonymous
  • 255 Answers
  • Posted on Sep 07, 2009
SOURCE: Blinking light on HP 932C Deskjet Printer
replace printer cart
On my HP F4180 the red light beside reume keeps blinking and I cannot print
Carriage jammed , check for that, if found any objects, remove to manually.if no objects observed might be service station strucked.. check it..If found difficulty, printer needs service..
`HP Deskjet F380 All-in-One Printer-Scanner-Copier E light is on seeming to refer to an ink cartridge issue. I installed new black and color ink cartridges. Light is still on and printer won't make...
Issue: Print Cartridge light is blinking
NOTE: In addition to the blinking light, an "E" might appear in the Copies area.
Solution
Close the print cartridge door.
Cause
The print cartridge door is open.
Hp deskjet d1320 yellow light keeps blinking
Thank you for suggesting that the cartridge might be bad. I almost got rid of my deskjet D1320 because it was blinking continuously and I could not figure out why. I tried everything from new driver to looking for a paper jam and nothing worked until I tried your suggestion. I tried each of the cartridge separately to find out that the black cartridge was making the light blink but not the color on. I replaced the black cartridge and the printer is fine now
1helpful
Printer (HP deskjet F4180) showing E and color
This means that there is issue with the Ink Cartridges.
Please remove and re-insert the cartridges.
Check the expiration date on them. Also make sure that you are using genuine HP Cartridges, not refilled or Remanufactured.
If the issue still persists, please replace the ink cartridges.
It says E in the small display screen it has and
Turn the printer off.
Disconnect the AC power.
Reconnect the AC power.
Turn the printer on.
Start the HP Support Tool software on your computer, and check the ink-levels on the printer -- no ink means no printing.
Do the lights blink in a specific, repeating, pattern?
Have you looked at http://support.hp.com and entered your model-number, and looked at the "common trouble-shooting" suggestions?
3helpful
2answers
Hp Deskjet F4180 and incompatble ink #27
This cartridge is no compatible with your printer. You could use refill kits for your original cartridge so you always have ink arround.
Try here for more options
Scanner wont work The letter E is on. Lights are blinking
Un-hook it from the computer. Turn it off then on. See if it may be a code from the computer causing it.
Also, Check inside and make sure there isn't anything that is keeping the carriage from moving freely .
Also, Have you changed cartridges lately?
Reseat the cartridges.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
k24674
Grand Canyon Tech
Grand Canyon Tech
