Depending on brand, you can either connect the printer to wired ethernet connection and then adjust the wireless settings, or perform a factory reset on the wireless.
hi . if the logo of wi fi highlighted its the board wifi hardware problem & there is no solution sorry . don't waste your time just go to apple store & pay them 160$ to exchange your phone whit working refurbushed one .
Did you loose WiFi access password or router password? If it's WiFi password then you can connect over Ethernet cable, login to the router (default password is blank) and change WiFi password. If it's router password you will need to reset it to factory defaults and setup everything from scratch.
Connect directly to the router using an Ethernet cable if you haven't already and go to http://192.168.2.1 . Go to the Wireless > Security and input the new password.
Reset your router to factory default settings for that press RESET button for 10 seconds it is in back side of router then all settings defaults.Then configure your router with below method then all messup will be fixed. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on WAn settings and set wan settings as internet service provider settings. Then click on wireless settings then enable wifi also enter SSID name and enable broad cast turn on wifi . If you want to secure wifi then enable WEP in wireless security .Enter code it is your password to connect wifi. Let me know if you need further assistance. Thanks for using FixYa.
http://192.168.15.1
or
http://192.168.2.1
