Vacuums Logo
J
John Jones Posted on Jan 27, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I remove the head/change the nozzle on unidentified vacuum?
I am using a friends vacuum & I cannot work out how to remove the head/change the nozzle?
Claude Kayser
Level 3:
Top Expert:
  • Master 9,098 Answers
  • Posted on Jan 27, 2016
Claude Kayser
Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067434
Points
28436
Search Results
    DC28 Cleaner Head Replacement Removal - YouTube
    ? 17:19
    https://www.youtube.com/watch?v=yERbv8owKU4
    Apr 2, 2013 - Uploaded by AllVacuumBrandsCTN1
    DC28 Cleaner Head Replacement Removal ... Dyson DC28 Animal - King of Vacuum Cleaner For Pets Hair ...Missing: nozzle ‎unidentified
    Dyson DC24 - Replacing the cleaner head (Official Dyson ...
    ? 0:55
    https://www.youtube.com/watch?v=PeI8N2SuXkM
    Sep 29, 2011 - Uploaded by AskDyson
    How to replace your Dyson DC24's cleaner head. ... Our brush bar reset guide shows how to remove the ...
    How to replace a Henry floor tool on a Numatic ... - YouTube
    ? 0:47
    https://www.youtube.com/watch?v=AUEaFIIFmeg
    Apr 15, 2010 - Uploaded by eSpares
    For all your Numatic vacuum cleaner spare part go to http://bit.ly/1G0FaXS If you've cracked the floor tool ...
Electrolux Epic: POWER NOZZLEM NOT WOKING
Connect power head directly to power without wands and see if’s working
If it’s working you have problems in wands or true hose
If power head is not working directly connected to power you have problem with reset switch or power head motor
Try to push reset switch several times
You have to test hose and wands for continuity and eliminate things by things
How do I installa new hose to the mortorized brush head on my shark lift waway
Hi, it's Allie from Crucial Vacuum!
Replacing your Shark Floor Nozzle Hose is very easy. Start by unplugging your unit to avoid any safety hazards. The floor nozzle hose's side that attached to the floor base of your Navigator can easily be pulled away. The other side of the floor nozzle hose has two tabs that can be pushed in while pulling it away from the base.
When installing, connect the floor nozzle hose to the canister first by pressing both side tabs while placing it until it click in its place. Then connect the hose to the floor base.
You can purchase direct your replacement hose and filters from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=NV352
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Alejandra (Allie) Sepulveda-Rivera
Crucial Vacuum Customer Care
2answers
How do i replace headlight bulb on an electrolux epic
To be honest, It's simpler to take it to any vac shop to replace at a nominal cost than it is to explain how to through all of the steps to do so yourself but I'll try. Basically, remove 6-7 screws from the bottom of the nozzle head, take a medium flat bladed screwdriver and gently pry back on two accessible internal tabs in the bottom rear of the nozzle head in order to pop the top of the power head off. Remove the top and there you'll see how easy it is to change. You can use a 15W or 25W bulb. Reassemble and VOILA! You're back in the spotlight! Hope it helps!
How do you change the scrub heads on a Floormate SpinScrub 500?
Hey there! To change out your brush heads simply follow the instructions below.
1. Remove the nozzle by pulling the two nozzle release buttons.
2. Tilt cleaner back so handle rests on floor.
3. Push two brush release buttons and remove the brush assembly.
4. To replace brushes align post on brush block with hole on bottom of cleaner. Turn brushes slightly until post fits easily into hole. Press brush assembly firmly to snap into place.
Hope this helps!
The nozzle is blocked up i'm assuming with limescale. I've tried soaking it in descaler but it still won't work. The buggy is working but need the nozzle for any sort of power.
If you can not get the power nozzle to work then the best thing to do is take the nozzle to the local vacuum store(used) and they will tell you the best advice weather it be fix the old one or replace the head. You can pick up a brand new head for around 99.00 up to 350.00 depending on what you want and they have come a long way in the past few years so take a look at a couple new ones.
47helpful
How do I change the belt on my Sears vacuum?
Here's what you'll need to replace a belt on a Kenmore2_bing.gif canister vacuum:
- Phillips Head Screw Driver
- Flat Head Screw Driver
Here's how you can replace the belt on your Kenmore Canister vacuum cleaner. First, before taking apart the power nozzle to change the belt, try pressing the overload protection system reset switch. This overload protection feature is designed to shut off the power nozzle if something gets stuck in the brushes, to prevent the belt from breaking. On most Kenmore models it's either a grey switch cover to the right of the neck for your power nozzle, or it could also be a little red colored pole. The reset switch will turn all power off to the power nozzle. If you turn on the vacuum, and try turning on the power nozzle and you hear absolutely no noise, then it's possible it may just need to be reset. It also could mean that your hose may have a short circuit in it (pretty common on Kenmore), and the hose is not getting power down to the power nozzle. If however you turn on the power nozzle, and you can hear the motor in the power nozzle come on when you switch it to carpets, then mostly likely your belt needs to be changed. On the model that I was fixing, the reset switch is a grey color, and I highlighted the reset switch in red:
So we'll just say for this repair that you are able to hear some noise come on in the power nozzle, but the brush is still not turning. This indicates a bad belt. Here's how you can fix it:
Step 1. If you're power nozzle is a square shaped nozzle like the nozzle that I took a picture of above, then you'll need to first remove the headlight cover before you can access the roller brush and belt. Simply squeeze both sides of the headlight housing, and while squeezing, lift upwards with your fingers exactly where my fingers are located in this picture:
Step 2. After the headlight cover has been removed, you'll see two screws underneath of the headlight cover, directly in front of the neck of the power nozzle. You'll need to remove both of these screws. I have circled these screws in red:
Step 3. After both of these screws have been removed, turn the power head upside down, so the roller brush is facing upwards. Look on the both the left and the right sides of the power nozzle. You should see writing that points to an area to put your flat head screw driver. You'll need to put the flat head screw driver down inside of the nozzle, and pry the top blue housing from the black bottom housing. Here's where the screw driver should go on the left side0723429.jpg:
Here's a picture of the screwdriver prying off the right side:
Step 4. Now turn the power nozzle back over on top, and remove the top housing of the nozzle. You may have to push the handle release pedal in order to take the top housing off.
Step 5. Once the top housing has been removed you should now either see a white semi-circle shaped housing over top of the brush, or your model may not have this part (some did and others didn't). If yours has a long white part over top of the power nozzle, look at the back corners of this white colored housing, and you'll see two clips, one on each side. You need to push these clips in, and pull backwards at the same time.
Step 6. Once this white colored housing has been removed, or if you model didn't have this housing, you'll now have full access to the roller brush and belt. You should instantly be able to see the belt if it's broken, as it won't be connected to the roller brush. Simply pull straight up on the roller brush to remove it from the vacuum cleaner:
Step 7. Wrap one end of the belt around the metal motor shaft in the back of the nozzle. Wrap the other end through the roller brush, and stretch the brush back into the housing where it belongs. Simply reassemble the parts, and test the vacuum to make sure the brush spins!
If you don't hear the power nozzle motor come on when you change the hose from Floors to Carpeting, this either means the reset switch needs to be pushed, or that you have a bad hose that needs to be replaced.
If you would like help on how to diagnosis the electric hose to see if it's bad, please just use the Clarification Request here on Fixya. If you have any other questions, please feel free to ask me, I'm always more then happy to answer follow up questions. If this repair was helpful to you, please be sure to rate it as helpful by clicking the thumbs up icons at the top of the repair.
Thank you very much,
Chris J.
GoVacuum.com
1helpful
See were to put the swr driver on both sides and not sure where to pull up
I'm pretty sure you're asking about a Kenmore canister vacuum,
There are two different types of belts2_bing.gif that are used on a Kenmore Canister. One of them is called a cogged belt, which has little teeth on the inside of the belt. The other is called a serpantine belt, which looks like a car belt, and has little grooves on the inside of the. You'll be able to tell which on yours takes after opening up the power nozzle.
This is the Cogged or Geared Belt with little teeth inside the belt:
Kenmore Canister Geared Belt for Canister Vacuums
This is the other Serpantine Belt that has little grooves on the inside of the belt:
Kenmore Canister Serpantine Belt for Canister Vacuums
Here's how you can replace the belt on your Kenmore Canister vacuum cleaner2_bing.gif. First, before taking apart the power nozzle to change the belt, try pressing the overload protection system reset switch. This overload protection feature is designed to shut off the power nozzle if something gets stuck in the brushes, to prevent the belt from breaking.
Step 3. After both of these screws have been removed, turn the power head upside down, so the roller brush is facing upwards. You should see writing that points to an area to put your flat head screw driver. You'll need to put the flat head screw driver down inside of the nozzle, and pry the top blue housing from the black bottom housing. Here's where the screw driver should go on the left side0723429.jpg:
Chris J.
GoVacuum
Apr 07, 2010 • Vacuums
51helpful
4answers
Need to replace belt in Kenmore Vacuum Power-mate nozzle
Here's what you'll need to replace a belt on a Kenmore canister vacuum:
There are two different types of belts that are used on a Kenmore Canister. One of them is called a cogged belt, which has little teeth on the inside of the belt. The other is called a serpantine belt, which looks like a car belt, and has little grooves on the inside of the. You'll be able to tell which on yours takes after opening up the power nozzle.
Chris J.
GoVacuum
4helpful
2answers
Kenmore progressive/direct drive-- roller stopped turning
We have the same vacuum & had the same problem. As the vacuum ages & the hose is periodically removed from the nozzle to use with the attachments, the white switch, adjacent to the nozzle connection, wears. If the hose is not fully reinserted or if the attachment notches are inadvertently aligned with the white stitch, the agitator may not work reliably. Assuring the hose is fully inserted, with the locking notches away from the switch has eliminated this problem with our vacuum cleaner.
2answers
Re-attaching the vacuum
With the nozzle off, turn the big knob until it locks, (will only turn one way) also make sure the belt is in the center, then turn the knob, put the nozzle back on and lock it down. Then turn the knob again and then the belt will be put on the spindle. Next time, before removing the nozzle, turn thast knob until it locks, then remove it, then it will be ready when you want to put it back on.
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
