I need to replace the Tcon board I have removed all the panel screws but in order to remove the back panel I must remove the power button cable. It appears I need to push in the outer plastic part and pull. However I am meeting a lot of resistance and I'm worried that may not be the way to do it. Any help would be appreciated
SOURCE: tcon board location
There are 2 hinged black retainers. Gently pry them up and the ribbons slide away from the board.
SOURCE: Hello, I have a Samsung LN-S4692D.
You cannot test the T-Con bd with a meter. However if you have the luxury of having another same model tv, you can install the bought T-Con bd and see if it is good or bad. Since you said the Menu and channel flashses, then I would replace the Main board.
SOURCE: LCD TV no pic but sound, do have all screen glow..
What is the Samsung Model number so I can do a cross match of the Tcon board?
SOURCE: how do i remove the back panel from a samsung ln22b360
Some of these sets use tabs inside the edge or gap of the cover--I use a thin putty knife to slide into the gap slowly and snap them loose working from left to right around the cover.
Screws it seems were not enough they had to do this.
since you have replaced the main parts in the tv already it is safe to say you have bad led strip these can be tested with a 12v dc power supply
