My Illy Francis Francis X9 is leaking
The issue you are experiencing with your Illy Francis Francis X9 may be due to a malfunctioning seal or gasket.
The coffee pod holder and brew head are sealed together with a rubber gasket, which creates a tight seal to prevent leaks. If the gasket is damaged or worn, it may not create a proper seal, causing water to leak out of the machine.
I believe to troubleshoot this issue, you can try removing the coffee pod holder and inspecting the gasket for any damage or wear. If you find any issues with the gasket, you can replace it with a new one to ensure a proper seal. You can purchase replacement gaskets from Illy or from a third-party supplier.
Another possible cause of the issue could be a clogged or dirty brew head. Over time, the brew head can become clogged with coffee grounds or other debris, which can cause water to leak around the edges. To clean the brew head, you can remove it from the machine and soak it in a solution of hot water and white vinegar to remove any buildup or debris.
It's also possible that the issue is related to the machine's pump or water flow system. If the pump is not working properly, it may not be able to generate enough pressure to push water through the coffee pod. In this case, you may need to have the machine serviced by a qualified technician to diagnose and repair the issue.
