New carb has a solenoid on bottom, old one does not
I believe the electric solenoid is a fuel shut off. solenoid needs energized, normally with switch 12 Volts. other then float bowls are the carbs. identical, if they are switch bowls, should work. If not you will have to add switched power to solenoid, the link below looked similar to yours.
Generac Generator Carb removal and disassembly
McCulloch Generator Model FG5700AK
