? 4:49
https://www.youtube.com/watch?v=k7lbl6irj4E
Sep 24, 2011 - Uploaded by Scotty Chezz
Hey, guys! Here's a video on how to connect a PS3 to a very old TV. I hope this will be useful for those who don't have an HDTV. ... Loading... Autoplay When autoplay is enabled, a suggested video will automatically play next.
Does you tv hav the yellow, red, and white, connectors? If not, then you are out of luck. If you are using the s-video connection, looks like the wire for cable tv, then you need a signal splitter and you should be able to connect your system to your tv.
It's a semi-long process. Do you have a wireless router hooked up to your computer? If so just go to settings then network settings in your ps3 menu. If you have the wireless router then put wireless connection and its straight forward from there. If it is a wired connection and hooked to your ps3 than put wired connection and again its straight forward from there.
You have to connect the wire that has 3 separate wires at the end into your television according to the color. Plug the red wire into the red slot, yellow in the yellow and white in the white. You will then have to take the other end of the wire and plug it into the back of your playstation. Also, make sure to plug your playstation into the electrical outlet.
Do you have the remote? You will need to cycle through the inputs to get to video 1 or 3. You might have the buttons on the front of your tv that says tv/video or tv/vcr. If not go down the channels past 1 and it might automatically switch through the video input selections. For any of these solutions have the PS2 plugged into video 1 and turned on. Hope this helps.
i have a tv that only has the audio out put and video out put as well . and my playstation 2 works on it. just plug the white and yellow ends in to your tv and it will still work without you unplugging any cables. hope this helps.
I have a ps2 also so just hook up the yellow and white plugs. It will work if you connect those 2 right but you must have a remote to turn it to game mode or no lucc. This is where i'm at right now trying to find my remote..hahaha
