Question about Samsung LN-T4665F 46 in. LCD Television
Samsung LCD TV reboots repeatedly
Why does my tv reboot repeatedly
    Habit-Forming:
  • 132 Answers
Hi Bryan,
These models are notorious for failing electrolytic capacitors in their Power Supplies, get the part number from the Power Supply Board and google it with +repair kits, there are many different kits available to tackle differing symptoms.Heres a massive 17 capacitor kit on Anazon: http://www.amazon.com/Samsung-LN-T4665F-Monitor-Capacitors-IP-301135A/dp/B00LU4UMW6
Posted on Jan 24, 2016
Anonymous
SOURCE:
I have a Samsung TV (un75f6300afxza) and Reboots on its own. Sometimes it does it multiple times. The TV is not under warranty anymore and I would like to figure out what parts I need to replace.
Hello, do a software upgrade ( that's done through your tv's menu) and see if that takes care of your issue. If not, there's a cover over the WiFi receiver , unplug the tv and remove the small cover and unplug the WiFi and see if it still shuts off. Let me know.....tks
Jan 30, 2015 | Samsung Televison & Video
TV wont start up, blue power icon flashes 3 long and 1 short flash repeatedly
You need to reboot the tv. you've had a signal drop which locks up the tv. call sharp techicon1.png support and they will talk you through a reboot.
Apr 19, 2014 | Sharp Aquos Televison & Video
Tv shuts off when i plug anything in
It may help us to assist you if we knew the make and model of the tv.
Feb 11, 2013 | Samsung LN32C540 32 in. LCD TV
My LN40B530 Samsung tv comes on for about 15 seconds and then goes off. A minute later comes back on, and again goes off after 15 seconds. this goes on continuously. How to solve, please?
Hi my name is Roety,
I can help you with your issue ,
First upgrade to the latest firmware, reboot every device connected to the TV . If the TV menu is also rebooting replace the mainboard.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Oct 24, 2009 | Samsung LN40B530 40 in. LCD HDTV
Ln40a5op3p Samsung LCD 40" stopped playing sound while whatching tv. Using the regular antenna screw in for cable on the back of the TV NOT the yellow red and white cord. Xbox works fine for sound but...
Hi my name is Eric,
I hope I can help you with your issue ,
Do you have a cable box?
 First thing i think of is you need to reboot the cable box by unplugging it from AC power, then reconnect it. (then reboot the Tv same way if haven't done that yet either) then its time to try it with AV cables
to make sure the cable box is not bad. using the red/white and yellow cables
then testing with another source like a DVD player, common sense will tell you if its the cable box or the TV.
If you've already done this or don't have a cable box (sorry),
The only thing in the TV that can cause you to lose audio only on TV is the SAP mode.
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Thanks
Eric
Sep 09, 2009 | Samsung LN40A550 LCD TV
REBOOTING CABLE BOX
i would imagine it is the tv but i would check your electrical outlet to make sure the ground and polarity are correct. you can buy a cheap ground and polarity check tool at most hardware stores...hope i was some help
Jun 12, 2009 | Samsung LN32A550 32 in. LCD TV
An annoying "2" in the upper rigth corner of my TV.
I had the same problem. I manually rebooted the box and the 2 was gone. Hope this helps.
Dec 21, 2008 | Samsung LN32A550 32 in. LCD TV
Samsung LN-T4665F 46 in. LCD Television Logo
89 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
