Hi.
I experienced the lens error message after taken the camera to the beach. Sure enough, there was sand all over the lens mechanism. First, I cleaned the area by blowing air to remove all sand particles (this took me almost a day). In my case, I did not have to remove the lens from the body of the camera. Once clean from dirt, sand or any other foreign object replace the batteries.
SOURCE: lens error
This can work with CoolPix S10
1) Remove battery.
2) Replace Battery (Insure it is fully charged)
3) Press the Shooting/Preview button and keep pressing it while you press the power on button. This tells the camera to go into PREVIEW MODE without checking the lens. See if you can preview a few photos and that it works in preview - If it does NOT I cannot help you here.
4) If the Camera Works in Preview mode then press the Shooting/Preview button to put it back into "Take Photo Mode".
5) There can be a delay but it starts up without the lens error.
6) Make sure the ZOOM IN and OUT works and in most cases if the lens operates then you can take a photo. If the Zoom in and Out does not work you have a jammed lens.
7) If the LENS is Jammed AND it is OUT of warranty you 'might' want to tap the lens barrel against your palm. I have found when you remove the battery you can gently tap the lens into telephoto mode by tapping the back of lens assembly into your palm.
SOURCE: Nikon Coolpix 5700 - Lens Error
sweet. this helped. I was just too lazy to find out on my own. lol. easy solution.
SOURCE: my nikon says lens error
Remove the 4 screws from the bottom 2 each from the sides, gently remove back leaving the wires and cables attached, remove 4 screws on logic board. left up slightly then set back down. Set the back cover in place put in batteries and test. When working put screws back in and your set.
SOURCE: lens error message on nikon
When system control does not get lens initialize signal while extending it, then it try again by folding it and extending and still no required initialize signal then generate error and stop further functions.
Please remove battery and open camera and remove flexible wire of lens mechanism from connector, there would be lock that needs to release to remove flexible wire. Clean wire terminals with alcohol, let it dry and put back flexible wire in connector and lock it. Now put battery and power camera up, hopefully lens will work properly.
Hit "add a comment" button for further query / info.
Thanks.
SOURCE: Re Nikon S220 digital camera. Lens error noted -
A tiny bit of grit can jam the gears of the lens. Sometimes a tap can knock it out. Try this at your own risk. Take out the batteries. Don't hit the camera on a hard surface, just use you hand. If it hurts, that is too hard. Try lens down, then all the sides.
