I tested 2 sticks of 4GB RAM in this computer. when i reinstalled the original 2 sticks of 2GB RAM, i get nothing on my monitor and i hear beep codes. 1 short, 1 long. have i damaged the sticks? or another component?
SOURCE: Dell b110 won't boot
On some PC's, the RAM MUST be put in a certain order. Also, when RAM is not completely seated, you will get what has been happening to your PC. MAke sure that the slots are lined up. push the RAM in with even pressure until you hear, and see the distinctive "click" of the RAM seating its self. Also, make sure that the computer is unplugged, and that you have discharged any Static from your hands before touching any parts of your PC. You could have damaged the RAM this way.
SOURCE: upgraded RAM in D51C, from 256 to 2GB, got 1 short beep, 2 long
It is the same... 1 short beep and 2 long..
SOURCE: HP Pavilion a6000n PC. M2N68-LA (NARRA GL8E)
if you are using a 32 bit operating system it will not recognize all of the memory in some instances or the mobo is not designed for more than 2 gb maximum check the mainboard (motherboard) website for specs on your model. sometimes you have to use 64 bit operating system to be able to get the full use of memory over 2 GB
Hi sportroy , we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
what is the motherboard bios number
what is the type of memory your motherboard supports ?
What speed of memory does motherboard support ?
the bios number flashes on the screen during power on press pause button to read it.
it may also be on a sticker on bios chip on motherboard.
hopefully you used esd precautions when handling memory sticks ?
