Http://h10032.www1.hp.com/ctg/Manual/c04204791
try this
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Gas vents that are spaced less than 8 ft horizontally from a vertical wall or similar obstruction shall terminate not less than 2 ft above any portion of a building within 10 ft.
I would think that the inspector would interpret this part of the manual as calling for a venting kit to be installed and run two feet at least above and part of the building within 10 feet horizontally.
So if the deck is attatched to the house, you will need this to be vented. If the deck is seperate, you might be able to get away with leaving it as is.
