If it blew the fuse, I would suggest there is a dead short somewhere. You will have to go through the wiring harness and see if any wires have been damaged or trapped and cut through to the frame of the bike. The frame is negative. The wiring will all be positive. If a bare wire touches the frame, it will blow the fuse.
Sounds like there is dead short somewhere, look for metal touching wires or terminals, or exposed wires touching the dash frame or floor under the carpet.
You have a short in the wiring of that fused circuit, or less likely that one of the mirror motors has a short. A short is an unintended path to ground, like an exposed wire touching body metal, or an internal motor failure. If that fuse is only for the mirrors and nothing else, it will be easier to find. A likely place will be in the door openings where the wires can get stretched and chafed. Pull the protective boot away from the wires where they enter the door, and check carefully. You may need to get to the mirror motors and to the switch for them. If everything looks okay, better get a multi-meter to check sections of the wires for continuity. A wiring diagram will be needed to find the right color wires that you will be looking for. I am guessing that each motor will have 4 wires to it, 2 for side to side, and 2 for up and down. These 4 wires will come from the switch on the driver's door that operates them. Power travels from the fuse to the switch, and then to the mirrors, as the switch operates them. The ground wire for the mirrors will originate at the switch, or it may be a shared common ground at the driver's master switch for the mirrors and the power windows. The short may be in any of these wires, or in the switch (evident at the connector to the switch as melted plastic, perhaps), or a short in one of the mirror motors. Good luck and good hunting.
There should be two wires going to the switch. If you remove the switch and connect the two wires together it will allow the circuit to be complete and the machine will think the door is closed. Make sure the connection to the two wires do not touch the frame of the copier, use electrical tape to prevent a short in the line.
Hello. Try looking at the black earth that goes from the drivers door and into the A frame which is covered in a rubber sheath. The wire can break after opening and shutting the door over several years and as it's normally the thicker wire is more prone to break. Also check the other wires visually for any chaffing and tugging on each wire. If more electrical parts start failing, air con blowers etc it will be an earth. Hope this helps
A fuse blows when there is too much current drawn thru it. Let's say it is for the radio. If the radio is turned off and the fuse blows immediately then the power wire to the radio has a bare spot somewhere and is touching the metal of the car or the power wire is touching the negative wire. If it blows when you turn it on then the radio has a short inside or a malfunction causing it to draw too much current. Let's say it is for the dome light. If you put the fuse in with the door closed and the dome light is set for DOOR and blows right away then the short is in the wire leading to the door switch or the switch is shorting out, letting + touch the - metal body of the car. The entire body is negative. That is why there is usually only one big thick black wire on the battery for negative. If the fuse blows when the door is opened, then the switch is probably shorting out, or the wires going to the dome light. Generally when the fuse blows when you turn something on, then whatever you are turning on is probably junk, unless it is a stereo that draws too much power for the thickness of the wire, or the stereo is junk.
The short circuit may be located in the junction box from which the dishwasher gets power. Its probably bare wires touching under the "skirts" of two wire nuts.
If no power problems, then the dishwasher itself has a short. In this case, start locating the short in the little box to which the power cord is connected - these connections will short if one of the hot wires, or a hot wire spade lug is touching a frame ground (all components of the frame are grounded).
A third (remote) possibility is a wiring mistake - the dishwasher hot & neutral could be connected, causing a dead short.
Sounds like you have loose wiring or a short in the power door locks. Try looking behind the power door lock switch and work your way back through the door to see if there are any loose or bare wires touching on any doors with a lock button. A Chilton or Haynes Manual for your exact car may be found at a library or most auto parts stores, and they'd be able to give you the exact location and diagrams of the wiring for your power door locks. The dome light may be a loose or broken switch in the door that turns the lights on/off when you open/close the door, try tightening the bolts or nuts holding this switch to the door frame. Hope I could help.
I had a similar problem in my 1993 Safari. Problem turned out NOT to be a switch, but a broken wire in the driver side door opening between the door and the frame. I found a cut in the wiring insulation, and it corroded, breaking. This disabled the window control.
