Recently installed two fluidmaster 400 flush valves in two separate american standard 4083 toilets at end of flush prior to refill of tank I get a loud gurgle from both how do i eliminate this sound?
SOURCE: Flush valve drops before bowl completes flush
is the flapper weighted? if it is it will cause it to shut prematurely. one thing you can do is increase the water in the tank. you might have to buy a pvc cuppler to put on the over flow to allow it to fill up more. korky makes a nice flapper thats not weighted
SOURCE: I've just installed a Fluidmaster
The first thing I would check is to make sure that the body of the float or the linkage that connects the float to the top of valve are not rubbing on inside of the tank and stopping it from moving freely.
Also when tank is full hold float down so that all air that is inside the top of the float is let out. I hope this hepls you. Thanks.
SOURCE: since I replaced the insides
You are going to have to adjust the valve you just installed. Most can be adjusted by pulling a ring close to the bottom upward and pulling the neck of the valve up, in turn adjusting the water level in the tank. There should be instructions in the box on how to raise the water level.
SOURCE: After flushing the toilet with
hiya:) This is a result of a very minor design error (i am a big fan of FluidMaster products) combined w/a slightly higher than normal water pressure situation or foreign matter stuck in the valve somewhere. try turning down the water pressure via the shuttoff under the toilet tank:)
