Sony KLV-32S550A 32 inch Multi-System LCD TV Logo
m
mahes gunasekara Posted on Jan 22, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i remove the sticker in my LCD panel as it has a bubble efect
Level 3:
Top Expert:
  • Sony Master 76,851 Answers
  • Posted on Jan 22, 2016
Sony Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14986685
Points
237762
It can be peeled off.
  • mahes gunasekara
    mahes gunasekara Jan 22, 2016
    It is not peeled off and there are adhesive(glue) its not removing
What panel display will fit philips 47pfl3603d/f7
According to research, you set uses a LC470WUE-SAA1. I would suggest you double check by removing the back cover of the set. On the back of the LCD panel, there should be a white sticker that states the LCD panel model #
Lcd is cracked need replacement
You will need to take off the back cover of your set and look for a white sticker on the back of the LCD panel. The sticker will state the model # of the panel. YOU WILL NEED TO ORDER A PANEL MODEL # THAT IS EXACTLY THE SAME AS YOURS. Once you have the model #, you can google it and find a panel online.
Need a replacment lcd flat panel foe a Element tv
Check the number of the LCD panel and search for it on internet. There is model number to every LCD panal, can be noted on the panel itself; on a sticker. You have to open the TV to get detail about this.
2helpful
Fine lines all through my lcd tv
your Lcd panel has failed you will need a new panel but that company no longer in around how ever if you get the genaric number off the panel which is on a white sticker on the back of the panel best bet is take a picture of the sticker then do a google search
hope you get lucky
2helpful
Problems with ltv-32w3 hd After TV is on for 15 to 30 minutes the picture looks fuzzy and looks like a picture negative but still has color
You need to replace the LCD controller board, there are two versions (V320B1-C, 35D003848) you need to open up the tv and remove the shield cover to get to the LCD controller board, this is a common problem with this model. Look here parts (make sure to get the part number of the LCD panel sticker to match wit the LCD controller): http://www.shopjimmy.com/catalogsearch/result/index/?q=LTV-32W3HD&stock=all
You cam see the one I fixed here: http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Notes: be real careful when you remove the back cover, the side switch assembly is attached to the back panel, so do not pull it off too far, or you will damage the switch assembly!
1helpful
I have a deep scratch on my tv lcd screen,can it be repaired
Hi there! Depends on how deep the scratch is, you can try a bit of Glycerine Jelly to fill that scratch. It should dampen the efect somewhat but not a 100%. To repair will be uneconomical because the whole screen will have to be replaced, unless a repairer can source a good second hand panel for less. Best Wishes and Good Luck, JUS004
3helpful
HOW TO REMOVE PANEL LOCK ON A SANSUI LCD TV WITHOUT REMOTE
That tv usually has the customer service number printed on a sticker somewhere on the tv. Give them a call. They will help you for free. I hope this helps you.
2answers
Samsung lcd tv le40r8
if the unit is under warranty call samsung for the nearest authorized repair place. the problem is a bad main board.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
