Invacare Pronto M51 Power Wheelchair Logo
David Montgomery Posted on Jan 22, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why is insufficient power getting to controller?
It was working fine,when I had a stroke.it set 2 weeks now it is not getting power to the control. I can plug in the charger ,turn it on and the controller lites up.Batteries are fairly new.
Scooter Doctor
Level 3:
Master:
  • Invacare Master 401 Answers
  • Posted on May 15, 2016
Scooter Doctor
Invacare Master
Level 3:
Master:
Answers
401
Questions
0
Helped
122708
Points
1542
David,
have someone check the freewheel handles are in drive position, then unplug charger.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Automatic, shift 1 to 2 slip (cutlose and bang) when it shift between 2,500RPM and 4,000RPM works fine at light throttle and full throttle 1-2 shifts all other shifts fine 2-3-4 at any RPM
DTC C1275
PCM Requested ETS to Be Disabled
The PCM monitors various parameters and will not allow traction control operation if any parameter falls outside a specified range.
Conditions for Setting the DTC
The PCM diagnoses a condition preventing the engine control portion of the traction control function and sends a serial data message to the EBCM indicating that torque reduction is not allowed. The PCM will typically set a DTC and the EBCM will set this DTC.
Diagnostic Aids
This DTC is for information only. As an aid to the technician, this DTC indicates that there are no problems in the ABS/TCS system.
Step
Action
Value(s)
Yes
No
Schematic Reference: Antilock Brake System Schematics
Did you perform the ABS Diagnostic System Check?
Go to Diagnostic System Check - Engine Controls in Engine Controls - 2.2L or Diagnostic System Check - Engine Controls in Engine Controls - 2.4L
Go to Diagnostic System Check - ABS
Install a scan tool.
Does the scan tool power up?
Go to Step 2
Go to Scan Tool Does Not Power Up in Data Link Communications
Turn ON the ignition, with the engine OFF.
Attempt to establish communication with the following control modules:
• Body control module (BCM)
• Electronic brake control module (EBCM)
• Instrument panel cluster (IPC)
• Powertrain control module (PCM)
Does the scan tool communicate with all control modules?
Do you have a up scale scan tool ? One that will communicate with the above modules ? If not your best bet would be to take your vehicle to a qualified repair shop .
2answers
Remote not working
I would suspect a fault but check the batteries in the remote are fitted
correctly.
Chainsaw troubleshooting
Fuel can chemically decompose in as little as two weeks, especially if it's an ethanol blend. Try to avoid ethanol-blended fuels.
Dec 16, 2013 • Garden
Amp loosing power
The Eden has a thermostatically controlled fan, my first thought is to clean the fan and airways and make sure it is working properly. This relates to some heat problems on solid state stuff. If they get too hot, some shut off for protection, the fan should automatically speed up on this model to compensate. When volume is low watch the fan. Also, make sure the impedance switch is set properly. I've very rarely seen any reason to use 2ohms settings. The only way to run that is with 2 4ohm cabinets in parallel. If they are in series it would become 8ohm. Any other way will make the amp get too hot on 2 ohm setting. Most cabs are 4, 8, and 16.
Hi - I'm looking for an Instruction Manual for an Integrated Oven HJA3650. This can be branded Lamona / Diplomat / Beko (and is made for B&Q / Argos etc). Can you help please
hello,
Operators Manual
Circulating Bath withDigital Controller
110-118
rev. A
Table of Contents
Section 1. General Information
1.1 Unpacking
1.2 Package Contents
1.3 Description of Circulating Bath
1.4 Specification
1.5 Circulating Bath Fluid Connections To External Apparatus
Section 2. Operation
2.1 Location
2.2 Filling the Reservoir
2.3 Reservoir Fluids
2.4 Circulator Pump
2.5 Closed Loop Circulation
2.6 Power
2.7 Setting Temperature
2.8 Setting the High Limit
2.9 Setting the Safety Thermostat
2.10 Operation of Refrigerated Models
2.11 Operation of Heat-Only Models
2.12 Selection of Celsius or Fahrenheit Readout
2.13 Optimization of Controller
2.14 Controller Display Messages
Section 3. Maintenance
3.1 Heater
3.2 Pump Motor
3.3 Condenser and Air Vents (Refrigerated Models)
3.4 Cleaning
3.5 Maintaining Clear Bath Water
Section 4. Troubleshooting
4.1 Unit Disabled - Service Required
4.2 No Pumping
4.3 Insufficient Pumping
4.4 No Cooling or Insufficient Cooling
4.5 No Heating
4.6 Insufficient Heating
4.7 Triac Failure
4.8 Controller Default Settings
Section 5. Service and Technical Support
Section 6. After-sale Support
Section7. Warranty
1.2 Unpacking
Your circulator is shipped in a special carton. Retain the carton and all packing materials until the unit
is completely assembled and working properly. Set up and run the unit immediately to confirm proper
operation. Beyond one week, your unit may be warranty repaired, but not replaced. If the unit is
damaged or does not operate properly, contact the transportation company, file a damage claim and
contact the company where your unit was purchased.
Remove any loose packing material which may have fallen into the reservoir during shipping. Also
check that nothing remains around the heater or circulator pump. Before proceeding, be sure the
Power switch is in the OFF position. Refrigerated models should have the Cooling switch in the OFF
position.
All TC-101D TC-201D TC-501D
Circulator Bath
Operators Manual 110-119
3/16in., 1/4in., and 3/8in. Nylon Barbed Tubing Adapters 510-011
6 ft. of 1/4in. ID Latex Tubing 300-299
Beaker Platform(s) for Bath Reservoir — 600 ml 701-402 701-402 (qty 2) 701-402
— 1000ml 701-403
Deck Lid(s) — solid 510-209 510-209
— w/beaker holes 510-211 510-209 510-211
Blue Hole Plugs — 31/2 inch 300-295 300-295(qty 2) 300-295
Note: Do NOT Use Above 120°C — 41/4 inch 300-296
Note: Work area "opening" is designed to measure samples directly in the bath. If additional viscometer height
i
Aug 28, 2010 • Ovens
Heat controller furnace will not lite and seems to have no power ( it does )
pilot generator may be bad if you have propane heat.In some cases that can indicate a low voltage short ,or could have a bad transformer on unit
3answers
PS3 controller does not work after 2 weeks.
try plug in the carger to the ps3 then the controler then press the ps button
Peculiar Problem in LG studioworks 563N monitor?
Is there anything going on in Control Panel, Power Settings? Such as an auto off? Sometimes getting the monitor to come back on after it goes to "sleep" can be tricky. Usually a keyboard stroke works better than mouse movement. It almost sounds like a hardware problem and I would contact the manufacturer and see if it's still under warranty. I'm assuming the PC it is connected to isn't going off?
Top Invacare Health & Beauty Experts
ZJ Limited
ZJ Limited
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
