Microwave Ovens Logo
R
Ronald Wriight Posted on Jan 21, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you replace the damper switch on a Kenmore microwave, model 721.86013010
Claude Kayser
Level 3:
Top Expert:
  • Kenmore Master 9,098 Answers
  • Posted on Jan 21, 2016
Claude Kayser
Kenmore Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5066237
Points
28436
Microwave Vent Damper Replacement - GE ... - YouTube
? 3:15
https://www.youtube.com/watch?v=9sQco-DIqQ8
Nov 25, 2013 - Uploaded by RepairClinic.com
The most common reason for replacing the vent damper is if it i... ... video is applicable to the following brands ...
How to change the direction of a blower fan for an over the ...
? 1:45
https://www.youtube.com/watch?v=yhvuNOVN0R4
May 8, 2012 - Uploaded by Sparky Channel
For a great price on a Whirlpool microwave: Amazon.com: ... Howto change the direction of a blower fan for ...
Kenmore Microwave Parts - RepairClinic.com
Unit shuts down every 59 sec. No matter how much time, with or without anything in micro and I figure to replace motor and switch. How do I get to those parts in unit? Does it have to come down?
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Dacor-branded PCOR30-series microwaves are just cosmetically altered versions of the Sharp R1870-series ovens.
These Sharp-made models stop after 59 seconds when there's damper toruble.
See the attached sample drawing below for a typical damper assembly.
We have the applicable service manuals for the Sharp models and have uploaded it to our site here and here to help you in disassembling and troubleshooting your Dacor version.
You can find the Dacor PCOR parts list here and you can order Dacor parts by part number here.
If a switch is all you need, we offer a universal type for only $7.50 postpaid which you can order here.
You will have to remove the oven from the wall and remove the outer cover to access, test & replace damper parts.
Just refer to your installation instructions.
If for some reason you don't still have yours, scroll down to the bottom of this page to find yours.
3helpful
I Have a sharp microwave model # R1874. On the control panel, when I press the start button, the microwave runs for 59 seconds then stops. I have to press the start button again to have it run again. It...
That would be a problem in the damper assembly, either a bad switch or motor, or the damper door is jammed or blocked. Consult the attached diagram for general reference. The damper switch is the same as the primary interlock (door) switch.
Its location varies by model, but you'll have to take the outer cover off to find it.
The best place to order Sharp parts is Tritronics or you can call them toll-free at 866-779-5835.
If you only need a switch, you can order a universal type HERE
Also, I quote other similar solution...
I had the same problem. Turned out to be the micro switch and damper motor. I replaced both myself and fixed the problem for less than $40.00. The best advice I got was replace the switch, reconnect the motor and make sure the motor runs through a damper door cycle. It didn't run, even though it showed continuity and had power, so I replaced the motor which solved the problem. The micro switch which is activated by the cam on the damper motor has to be cycled within one minute, or the unit shuts itself off. The damper motor on my model R-1870 is found in the right rear section of the assembly when facing it. You have to remove the unit, and remove the outer casing to get to it. The damper is a simple sheet metal door, activated by the motor, and the switch mounts at the top of the motor and is activated by the same cam that activates the door.
Good luck.
10helpful
My Sharp micro will stay on for 59 seconds and shut off no matter how long the timmer is set. Sharp model r 1870 It does this every time it is used . The control board has been replaced.
This is not a problem on the board, it is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
Sharp models stop after 59 seconds.
See the attached sample drawing for a typical damper assembly.
We have the applicable service manuals for these models and have uploaded them to our site here and here.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
3helpful
Sharp convection microwave R-1870 runs about one minute and shuts off. damper Motor switch?
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you.
1helpful
Microwave oven shuts off after one minute
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
See the attached sample photo for a typical damper assembly.
What is your model number? We may be able to point you to the full service manual too.
The best place to order parts for this brand is Tritronics. Or you can call them toll-free at 866-779-5835. Their Web site re-opens tomorrow.
William E. Miller
[email protected]
http://www.microwavedisplay.com
Microwave operates for 59 seconds then shuts down.
Sharp-made models stop after 59 seconds.
We have the equivalent Sharp service manual for these Dacor models and have uploaded it to our site here.
You will need the
free Adobe Reader to view or print it.
Shuts off after 59 seconds
That would be a problem in the damper aseembly, either a bad switch or motor, or the damper door is jammed or blocked.
If you or a friend decide to look into it, we have critical safety information, switches diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
20helpful
4answers
Sharp R-1874 shuts off after 59 seconds
Over the stove Mircowave just reinstalled...light is on but not heating up
If any wiring on the control panel was or might have been disturbed, I would want to check that. It may be that something (like a sensor) did not get plugged back in. Otherwise, I would verify that the door switches are working properly and the mounts for them are not loose or damaged. If this is a convection model, also check check the damper, damper motor, and damper switch. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded views, and often service manual portions here: http://www3.sears.com/
Top Kenmore Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
