About a month ago, my Samsung LN52A580P6F TV started having the right half of the screen appear with rainbow colored vertical lines; while the other side was ok with sound and picture. Two days after the 1st rainbow vertical lines on the right hand of the screen appeared, the area went totally black. I have done the following and the picture is still black: • Used different HDMI ports problem still persists • Done the "flashlight" test on the right hand side of the screen and it is still solid black (no ghost image) • Opened up the back of the TV and the back lights are functioning on left and right hand side • Checked the power board for leaking / swollen capacitors and there are none • Finally replaced the T Con board I am puzzled as to what could be the problem if not the T Con board. Can it be the following: • Do I need new right hand (upper & lower) back light inverter boards? This Samsung TV has upper and lower inverter boards on each side of the TV • Did I need to update firmware in order to get the T Con board to work? There was an updated firmware in Feb 2010 (I bought the TV in November 2009) I plan to use an electrical cleaner spray on the ribbons connecting the screen to the T Con board and see if that helps. Other than that I am uncertain. I don't feel like buying a new back light inverter board if that is not the issue. Any help would be greatly appreciated. Thanks!
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - 24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
