I turned the power off and back on at the Electrical Box. Is there a way to reset the computer?
SOURCE: Hi i have a electrolux ewf 1074 front loader. it
Press and hold the 'Delay' and 'Extra Rinse' buttons together and it will 'unlock' your control panel (this is a tamper proof feature for the kiddies)
SOURCE: the start/pause button is flashing
timer is failed. replace the ECU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: The washing machine Electrolux 1087
Hi, if the washing machine stops in the middle of a wash cycle, the first step that should be taken is to perform troubleshooting steps to determine the cause of the problem. After the source of the trouble has been established, it can be resolved in most cases by continuing the troubleshooting process.
If after doing all these and the problem still persist, you have to call in a tech to check it out because there is no way to reset the Electrolux 1087
SOURCE: electrolux ew 880 f. Working
Disconnect the power supply for few minutes, say 15 minutes and then turn it on. This would reset the machine.If the problem persists, this would more likely confirm an internal issue and needs repair.If you wanted to repair it, kindly provide few more details :-
1. How old is the machine?
2. Any error message on the display?
3. Any sequence of beeps like 3 beeps, then pause and then 3 beeps or is it beeping continuously?
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: Electrolux EWF1074 with Error EH0. After 2 seconds
I Have the EWF 1073 and the same error EH0, and i found this link :
http://www.electrolux.co.uk/en-gb/Support/Troubleshooter/?Command=Detail&CategoryId=19&SymptomId=220&DetailId=220
It says :
Check the power supply. It's possible that there is not enough power. Remove any extension cables. If this is ok, it has to be repaired by a technician. When requesting a service, please state which error message it concerns.
Then i used 1000 Watt Stabillizer (stavolt), and it works normally.
WAKE THE WASHER BY PRESSING ANY BUTTON.
WAIT 5 SECONDS.
PRESS AND HOLD THE START AND PAUSE/CANCEL BUTTONS
SIMULTANEOUSLY.
ALL LED'S WILL GO BLANK AND AFTER A FEW SECONDS THE CONTROL
WILL SIGNAL THE STORED CODE USING AUDIBLE BEEPS AND BLINKING LED'S. THE CONTROL
WILL REPEATEDLY SIGNAL THE CODE, AS LONG AS THE START AND PAUSE/CANCEL BUTTONS
ARE PRESSED. A TWO-SECOND PAUSE BETWEEN REPEATS AFFORDS YOU THE ABILITY TO MAKE
ACCURATE COUNTS TO IDENTIFY THE CORRECT ERROR CODES.
PLEASE NOTE THE FOLLOWING: ON A SMALL NUMBER OF WASHERS WITH
SERIAL
NUMBER PREFIX XC4, IF THE PREVIOUS PROCEDURE DOES NOT PREFORM
AS
SPECIFIED, FOLLOW THE OPTION BELOW:
* FOLLOW ALL PREVIOUS STEPS BUT INSTEAD OF PRESSING START AND
PAUSE/CANCEL BUTTONS, PRESS AND HOLD OPTIONS AND PAUSE/CANCEL BUTTONS."
*THE CONTROL WILL PAUSE FOR 2 SECONDS, THEN REPEAT THE CODE AS
LONG AS THE TWO BUTTONS ARE PRESSED AND HELD."
NOTE: A LETTER APPEARING IN THE CODE STANDS FOR A NUMBER HIGHER
THAN NINE: A=10 B=11 C=12
D=13 E=14 F=15
"EXAMPLE CODE F1: THE FIRST
DIGIT WOULD BE 15 AND THE SECOND WOULD BE 1. IF THIS CODE WOULD APPEAR ON A
WASHER IN THE GOOD MODEL LINE, THE FIVE INDICATOR LIGHTS WOULD BLINK FIFTEEN
TIMES AND THE START INDICATOR LIGHT WOULD
