Geneva Platinum Womens Roman Numeral Link Watch Silver/Black Logo
How do you get it to work - Geneva Platinum Womens Roman Numeral Link Watch Silver/Black
Eco drive watch not working
Watch is not working had watch in window seal for the whole summer still not working
My armitron all sport watch works, it's only 1 month old, buttons stopped working. any ideas
try to put a new battery..whether it's only 1 mo old ypu can't tell the watch you bougth has a new battery inside.
2answers
Backlight for my breitling aerospace has stopped working, otherwise watch is working perfectly.
I am in South Korea. My back light has stopped working and I took it to the dealer/service office in Seoul and asked them if they could repair it. Then took it apart and said everything works find, but for the back light, I should just order a whole new analog works...is he just trying to make some money off me?
My watch stops working, the mechanism works on motion or kinetics. However, even with a bit of a shake it works for a bit then loses time and stops altogether
It may require rather more than a bit of a shake! Some makers say that you have to swing it gently form side to side for 200-300 times to fully wind up the watch.
I bought one some years ago that didn't work well and I had it cleaned, after which it worked perfectly for years.
If giving your watch the shaking I described above it still does not work, try having it cleaned.
Automatic watches thrive on being used but should run for 2-3 days before stopping.
2helpful
Athletic works watch owners manual
if you press both buttons on the right at the same time it might work. Im not sure if it will for ur model, but it worked for mine =)
Aug 17, 2009 • Watches
2answers
Light won't work
I suggest you have to check your battery first. It may be underpowered. Replace it with the new one and then check light again.
Top Geneva Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Geneva Watch Expert? Answer questions, earn points and help others
