SOURCE: my duravit toilet keeps running
I too have had this problem. No matter how i change the settings ..sooner or later the toilet starts to flow continually getting worse and worse. I have had plummers and friends etc see if they can make it stop and it is no better. I am very disapointed with it and will never ever buy Duravit again. I tried contacting them for help and got nowhere. Bad design. Waste of money.. I should have stuck with the old ball-**** system at B&Q.
SOURCE: toilet bowl gurgles after flushing cycle
Sounds like your toilet is not vented properly. Possilbly something caught in the trap is causing it to syphon
SOURCE: Toilet running about 2 seconds every few minutes
Tube in cylinder. Water should not come over cylinder, but 1/2" or so below.
SOURCE: water continually running into my toilet bowl.
IF YOU PRESS UR BALLCOCK DOWN IN THE CISTERN YOU WILL STOP THE WATER DRIBBLING IN THE TOILET ,JUST VERY SLIGHTLY BEND THE METAL BAR IN THE MIDDLE AND IT WILL STAY DRIP FREE,OR PUT A LITTLE WEIGHT ON THE METAL BAR NEAR THE BALLCOCK...ROB
SOURCE: OUr 5 yr old duravit toilet is constantly running.
if you can see the water running in the bowl it's a good chance that the flappers warn http://www.aplumbers.com/residential/toilet
1. tank the tank lid off.2. flush the rubber thing that comes up and allows the water to go to the bowl is the flapper 3. remove 4. replace that should fix it.
problem 2
1. tank tank lid off.2. if the waters flowing over the long tube in the center and down then the water level is too high3. adjust the level either it will have a ball **** or a float in either case a ball **** adjusts by a screw on the fill valve. the float has a either a metal rod w/ a pinch clamp or a plastic long screw type thing.4. adjust water level .5. barely lift handle to allow a little water out til fill valve kicks on then release handle til valve stops .6. just keep re adjusting til you get the water level right there should be a molded in line for the level on the back of the tank.
