II've plugged it in but it wont light up nor will the fans work
Koldfront 12 Bottle Stainless Steel Slim-Fit Thermoelectric ...
www.amazon.com/Koldfront-Bottle-Stainless-Slim-Fit...
Amazon.com, Inc.
Rating: 3.7 - 42 reviews
Koldfront 12 Bottle Stainless Steel Slim-Fit Thermoelectric Wine Cooler - Black/Stainless Steel ... Item model number, TWR121SS .... the fridge. so you hvae to take out a wine bottle to reach it an usually I would like the controls on the door and only turn in .... The door can be reversed which the description did not mention.
www.edgestar.com/Koldfront-12-Bottle-Stainless-Steel-Slim-Fit-Thermo...
Koldfront 12 Bottle Stainless Steel Slim-Fit Wine Cooler Primary Image ... steel, the Koldfront 12 Bottle Slim-Fit Thermoelectric Wine Cooler (TWR121SS) is ... cabinet and stainless steel accents ensure that this freestanding unit will look ... Power: 70 W/0.95 A .... Unfortunately, your browser does not support video elements.
www.walmart.com/.../Koldfront-12-Bottle-Stainless-Steel-Slim-F...
Walmart
$109.99 - In stock
First check to make certain the fan is plugged into the motherboard.
Follow the connector from the cooler unit to the m.b.
When you've located the proper plug - unplug it and then re-plug it back in, making sure it is firmly plugged in (make sure you turn off the power and unplug from the wall before doing any of this).
Then look at the fan closely and make sure it's not overly dusty or dirty.
This can clog up the fan and cause it to stop working.
If you've done all this and powered back up, and it's still not working - then you need to get a new fan.
Do not run your system without this cooling fan because you can fry your CPU.
DO NOT ATTEMPT TO OIL OR LUBE FAN THIS CAN END IN DISASTER
hope this helps
