After pairing, go to "Audio Device Settings" and select your new headset as the Input and Output device and adjust the Microphone level to 5, if you can see the meter flash when you talk, your headset is working correctly, then hit OK.
If you are talking about connecting a Bluetooth device to your laptop the laptop would not typically have a paring code. The device however may.
For example you would not be able to enter a code into Bluetooth headset as it does not have a keypad, so a code is pre-set into the device. Whatever the device you are trying to connect with see the manufactures manual or try 0000 as the code.
If however you are trying to pair with something like a mobile phone (providing both Bluetooth devices are set to "Discoverable") then you should be able to start the pairing from either the laptop or phone. Once the 1st device (That you has started the search/pairing from) asks for the pairing code you may enter ANY 4 DIGIT CODE OF YOUR CHOOSING. Once the is done you should be prompted to do the same on the 2nd device and you simply need to enter the SAME 4 DIGIT CODE.
This should complete the pairing.
Turn on your Playstation 3, and from the main menu go to Settings - Accessory Settings - Register Bluetooth Device You will be presented with two options: Register BD Remote Control Register Headset/Microphone/Headphones Select Register Headset... and put your Bluetooth headset into pairing mode. On your PS3 select Start Scanning Select your device and enter your pairing code. In most cases for audio devices the default pairing code is "0000" Now on your PS3, go to Audio Device Settings and change your "Input Device" and "Output Device" to your Bluetooth headset name. Try speaking and watch your "Mic Level" move!
