MY LOGIK WASHING MACHINE MODEL L612WMS13 SHOWS ERROR 12, THE POWER WENT OUT WHEN THE MACHINE WAS STILL WASHING AND WHEN IT CAME ON IT DIDN T CONTINUE THE CYCLE AND THERE IS STILL WATER INSIDE
I CAN T OPEN THE DOOR BECAUSE IT STILL HAS WATER INSIDE, I TRIED TO CHANGE THE PROGRAM, I TRIED TO DRAIN IT OFF BUT IT DOENS T START.AND THEN AFTER A COUPLE OF MINUTES SHOWS THE ERROR AGAIN
The error code H on a Logik L614WD13 washing machine means that there is a problem with the motor. The most common cause of this error code is a faulty motor, but it can also be caused by a problem with the motor control board or the wiring harness.
To remedy the error code H, you will need to identify the underlying cause of the problem. If the motor is faulty, it will need to be replaced. If the motor control board or wiring harness is faulty, they will need to be repaired or replaced.
If you are not comfortable troubleshooting and repairing electrical components, you should contact a qualified technician to fix the error code H on your Logik L614WD13 washing machine.
Here are some additional tips for troubleshooting the error code H on a Logik L614WD13 washing machine:
Check the power supply to the washing machine to make sure that it is turned on and there is no power outage.
Check the fuses or circuit breakers that supply power to the washing machine to make sure that they are not tripped.
Disconnect the washing machine from the power supply and then reconnect it to see if the error code clears.
Listen for any unusual noises coming from the washing machine, such as a humming or buzzing sound.
Check the motor coupling to make sure that it is not loose or damaged.
Inspect the motor for any signs of damage, such as burnt wiring or a broken fan blade.
If you have checked all of these things and the error code H is still present, then you will need to contact a qualified technician to diagnose and repair the problem.
Question edited for a lot more clarity 'make model (what it is)'.
Question moved from Washing Machines
Please don't type in all CAPS, it is considered SHOUTING and is harder to read.
There doesn't appear to be an 'Lf Error' anywhere. 'Low Freon', no idea, it's a guess?
Please, consider getting a users manual, and trouble shooting guide from https://manuall.co.uk/household-appliances/washing-machines/ignis-washing-machines/. The Error code can be decoded. Machine model will be needed. Continuously running pump would an indication the timing mechanism is not advancing. Sensor problem perhaps.
It is the customer fault code. Simply turn on and turn off appliance.
E11 - problem with fill water
E21 - problem with draining water
E41 - door open
All other errors require service staff !!!
Find the error code reference in your owners manual or check on the companies web site to determine the meaning of the error code and then try to fix .
Resolved the problem.
Switched off the power to the machine. hit the on /off button and the f-12 error code disappeared .
On reappling the power to the machine the orignial programme continued to completionj
