control panel administrive tools computer management device manager scroll to cd/dvd drives you should see either a red x or a yellow ! or a? right click to install drivers or
open up your computers side panel to access the lite combo drive unplug it then plug it in again from the electical lead
this should activate the found new hardware wizard then you might have to install the drivers for this device
Plug it into mains without battery.
Put the battery(s) into place. If batteries OK (but need charging) it will begin charging. If batteries very low it will cut off. If batteries charged it will charge only 1 - 10s.
First find out if you are dealing with a D2700 or the newer enhanced version. Press any 2 buttons and *,if you get a green LED and 6 beeps it is the new version. Old version remove battery and press any button. New version remove battery, press any number for 10 seconds,release, reconnect battery, press and hold the A button within 3 seconds, 6 beeps, release A button. the lock is at default and ready to program. To program new version 12345 A1A new combo A new combo this will set a new master code, if you are only using 1 code to open the lock this should suffice.
well go to your battery store or what ever has ds battery packs buy a knew one it is because your battery cant charge anymore so get a new one and it should work otherwise send it off to nintendo
I have a different model but I had the same problem. Called customer service and they had me push up on the handle and enter the code. That didn't work but then they had me tap the safe with a rubber mallet 5 times above the panel and 5 times to the right of the panel. That worked for me. Hope one of those works.
