In the image below are the instructions to enter and run the diagnostic routine. If the process is done successfully all of the LED light will come on for 5 seconds then display the last error. Push the same button until the error code ends and all the lights come on again for 5 seconds then the test will start.
If the test runs through okay then the central control unit is most likely okay. If it fails to enter diagnostic then the control has failed and needs to be replaced.
LINK FOR IMAGES: http://media.fotki.com/1_p,wbqgggwgkbbqkffxgtqsskgwtqkq,th/kdrdrkfgsxkdqfbbssk/1/1303472/5961991/image46797img-th.jpg
Please rate this solution. Regards.
