no one but the technician you get in to diagnose the fault will be able to give you answers to make that decision
with no lights there is no power so the initial indications are that the fix will be less than a new unit
they only become costly it the compressor is unserviceable
First take a cord and hook it to the motion lite and make shure it works .Remember that it only will work at night or dark area and you have to have lights in the fixture to make the contact.and make shure the plug is not on a dimmer or the wires are flipped. WHT. To the common side and black to the darker side and it has to be grounded .exspeacily if it is a led fixture.
Did you test the power outlet with another device...Sometimes a power outlet will fail under the load of a high current appliance like a drier...If the drier runs on 220 volt current...and have circuit breakers instead of fuses...make sure the 220 volt breaker for the dryer is not tripped...If it is tripped...reset it....if not...have a tech to check the outlet. oncee it is established that the drier is getting power and still not working...you may want to get it checked out by service personnel....Hope this was helpful....PEACE.....
Hi dear.If the washer is tripping circuit breaker,as long as you plug in,there is a Interference filter capacitor inside of the machine.Main power gets connect there first.It should be faulty & needs to be replaced.I hope that helps Thanks.
Make sure that the microwave is plugged into a grounded outlet. It must be a 3-prong outlet.
Make sure the clock is set.
Check to see if a programming sequence was entered.
Sometimes improper programming or a program sequence such as delay
start can cause the touch panel to be non-responsive. Unplug microwave
or turn off house circuit breaker for 30 seconds. Plug back in, or
reset circuit breaker, and try reprogramming unit.
Check the house circuit breaker or fuse box. If the microwave is DEAD and there is no display and nothing works- the problem could be a blown fuse or tripped breaker.
did any outlets stop working, mat be a tripped or bad breaker in elect. panel she if one breaker is tripped. flip off and back on, could se short in fan but unlikely. if cannot see tripped breaker, turn off computor, tv, any appliance you have on and go down breakers and flip off and back on. if a short is present one breaker will trip back off. call repair
