Televison & Video Logo
Tom Tonjes Posted on Jan 19, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tv turns on for 10 seconds and then turns off. Then a red flashing blinks 6 times and repeats
Claude Kayser
Level 3:
Top Expert:
  • Master 9,098 Answers
  • Posted on Jan 19, 2016
Claude Kayser
Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5063742
Points
28436
Search Results
    Samsung TV On/Off Issue - Repair - Instructables
    www.instructables.com/id/Samsung-TV-OnOff-Issue-Repair/
    InstructablesThe result of this issue is a TV that will cycle between on and off repeatedly and/or an annoying clicking noise while turning on. Time to get informed about the ...
    Easy fix for new Samsung TV switching on and off power ...
    ? 4:41
    https://www.youtube.com/watch?v=H0cG3lzjuw8
    Sep 15, 2012 - Uploaded by alwaysafix
    www.alwaysafix.com Find the correct TV part for your TV and more at ShopJimmy.com Click Here: http ...
    Samsung 46" LCD TV (LNT4665F) turns off and on over again - Forums ...
    www.cnet.com > Forums > Samsung
    CNETAbout 3-4 months ago, my TV would start turning off and on a few times at startup but eventually would stay on after a couple of minutes. Every once in a...
    Samsung TV turning off [Solved] - Samsung - Displays - Tom
Can you help diagnose a tv with no picture or sound? just a baclklit and flashing red indicator light
The red light flashing is indicating the error.
depending on the make and model of the TV, the duration of the flash and number of flashes determines the error code.
Sony bravia kdl-32bx300 wont turn on
https://community.sony.com/t5/Television-General/Red-light-blinks-6-times-tv-won-t-come-on/td-p/47107
I have a Plasma TV with black screen and 6 red light flashes.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
3helpful
4answers
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
How do i key in code for digibox
TO PROGRAM THE remote USING THE 3 DIGIT CODE:
1. Turn on the TV receiver
2. Press TV on the Sky Remote Control
3. Hold down SELECT and the RED buttons together for approximately two seconds, until the RED LED on the Sky remote blinks twice.
4. Enter three digit code from list for the receiver (early versions now flash twice).
5. Press select to enter code structure (the LED will flash twice if a valid code has been entered).
6. Now press the STDBY button and test other functions.
Repeat if necessary until a code is found that works most common functions.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
If at this point the LED on the Sky remote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV.
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
If after trying this, you still have problems, call your broadcaster's help desk. For your broadcaster's help desk number, select the Telephone Numbers option from the Services screen.
15helpful
2answers
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
1helpful
TV Sony KV-29F1E turn-on failure, red standby LED flashes (starts after 10-20 attempts)
When the set ends up flashing the LED, it should be a repeatable count. Can you please report that count here? Also, since the set eventually works, I'd suspect a bad connection or a part that has changed value over time. The blink code will help to narrow down the offending circuit.
Dan
2answers
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
