3800 3.8L GM engine stalling issue quick fix - YouTube
? 10:06
https://www.youtube.com/watch?v=XCu_OJu53Rw
Nov 21, 2013 - Uploaded by knurlgnar24
3800 3.8L GM engine stalling issue quick fix ... crank shaft sensor replace 1998 Pontiac Bonneville 3800 motor - Duration: 12:53. tlcbear2 ...Missing: bosch lumina stgill
GM 3400 / 3100 3.1 3.4 Engine Misfire Cause & Causes ...
? 8:58
https://www.youtube.com/watch?v=sw9cG8MaECU
May 25, 2013 - Uploaded by Vacationtime247
The spark plug and wire were replaced along with a new coil. Could hear the injector firing with a stethoscope but still had the miss. Found out .... What to do to start engine changed 3.4 to 3.1 in 04 Chevy impala ... Who the hell puts Bosch plugs in anything much less a gm. .... Fuel pump works fine also.
How to Test the 3.8L GM Crank Sensor With a Multimeter
troubleshootmyvehicle.com > GM > 3.8L
Oct 24, 2011 - The 3X-18X crankshaft position (crank) sensor, on the GM 3.8L V6 engine, can easily be tested (to find out if it's bad ... The PCM (Powertrain Control Module=Fuel Injection Computer) will not pulse the fuel injectors. ... 1993, 1994, 1995, 1996, 1997, 1998, 1999, 2000, 2001, 2002, 2003, ... Monte Carlo 3.8L.Missing: bosch stgill
3400 Sensor Locations - GreatAutoHelp.com
