Most wash machines hav a cable to balance it start with that
Most likely suspension rods are bad if a top loader. If front load, maybe shocks are bad or bearings are bad in tub.
Why does my Maytag washer model MAH8700 shake on 2 ...
www.shopyourway.com > Manage My Life > Questions
Apr 9, 2009 - I have a Maytag Neptune washer model MAH8700AWW. The serial ...cycles. It spins the water out fine. ... The pedestal in secured to the washer, but still vibrates during the spin cycles. ... Is a new control board the only answer left to stop the shaking? ... Bravos® Top Load Washer w/ PowerWash® System.Missing: bangs
Washer Diagnostic & Repair-Banging noises -Whirlpool ...
? 11:23
https://www.youtube.com/watch?v=-N39ZXZTWwc
Jun 13, 2013 - Uploaded by ApplianceVideo.com
Service your Whirlpool Washer suffering from some of the following dilemmas: ... Washer Diagnostic & Repair-Banging noises -Whirlpool,Maytag .... All Comments (48) .... 2-3 "Drain &Spin" cycles before the clothes are spun out sufficiently .... GEWasher Top Loader Out of Balance Shaking Repair Tutorial ...
Maytag PAV2300 Top Load Washer Clothes shakes ... - Fixya
1st make sure all four feet on bottom have equal pressure on them , then this machine if made past march of 2010 has a gyro on it that is suppose to redistribute the load around if it gets out of balance , it should try to spin if it detects a out of balance then its suppose to stop , add more water, agitate, then try to pump out an spin again , it can try this like three times or more if it recurs then machine is either overloaded or the gyro balance is not working
Replace all four struts
One thing to understand is that this is a difficult problem to pin down and may end up requiring the control board to be replaced.
The UL or unbalanced load error is displayed when the control board senses an out of balanced load.
You don't indicate if the washer is actually out of balanced or not when the code appears but the description of banging and shaking would indicate it is out of balanced.
If the washer consistently bangs and shakes in spin then I's suggest you remove the spin basket and check under it for obstructions that might prevent the washer from spinning smoothly.
